kenzo14 Posted November 12, 2007 Report Share Posted November 12, 2007 can anybody in likeard grind rims Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted November 12, 2007 Report Share Posted November 12, 2007 Yet again another pointless, effortless topic, do it you're self ? Quote Link to comment Share on other sites More sharing options...
kenzo14 Posted November 12, 2007 Author Report Share Posted November 12, 2007 Yet again another pointless, effortless topic, do it you're self ?i cant Quote Link to comment Share on other sites More sharing options...
The Stig Posted November 12, 2007 Report Share Posted November 12, 2007 Yet again another pointless, effortless topic, do it you're self ?to be honest it isn't the easiest thing to do. But he is right try using the Wiki and doing it yourself. heres my version:1. Remove your rim2. Take tyre and tube off3. If you have a grinder using a cutting disk and using from 45 degree angle to a 90 degree angle run the grinder over the rim.4. the less of the angle the less harsh grind5. clean up and have a great time riding Or use this http://www.trials-forum.co.uk/forum/index....amp;hl=grindinghttp://thrashed.blip.tv/file/280326/Thanks Tom Quote Link to comment Share on other sites More sharing options...
kenzo14 Posted November 12, 2007 Author Report Share Posted November 12, 2007 to be honest it isn't the easiest thing to do. But he is right try using the Wiki and doing it yourself. heres my version:1. Remove your rim2. Take tyre and tube off3. If you have a grinder using a cutting disk and using from 45 degree angle to a 90 degree angle run the grinder over the rim.4. the less of the angle the less harsh grind5. clean up and have a great time riding Or use this http://www.trials-forum.co.uk/forum/index....amp;hl=grindinghttp://thrashed.blip.tv/file/280326/Thanks Tomthanks good vid Quote Link to comment Share on other sites More sharing options...
benlt Posted January 15, 2008 Report Share Posted January 15, 2008 can anybody in likeard grind rimsPENGELLY CAN APARENTLY Quote Link to comment Share on other sites More sharing options...
Grant Hundley Posted January 15, 2008 Report Share Posted January 15, 2008 (edited) PENGELLY CAN APARENTLYWELL DONE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11111HAVE A COOKIE>EDIT: Yeah just smash your rim with a grind, skim the disc across the braking surface, may need to do like 3 lines next to each other to cover the whole sidewall.Just get an old rim and try it out, you'll quickly see how easily it can be done.For harsher grinds just push down more, tilting the grinder at a different never seems to make a difference for me Also, there isn't really a need to take your tyre off, I never do and never have problems. Just makes the sidewalls of my tyres look a bit scruffy. Edited January 15, 2008 by Grant Hundley Quote Link to comment Share on other sites More sharing options...
chrisbikefix Posted January 16, 2008 Report Share Posted January 16, 2008 when i have done grinds in the past i have put the wheel in a vice via the end of and axle , so when you girnd the rim, the wheel turns with it so it gives a nice smooth finish! Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted January 16, 2008 Report Share Posted January 16, 2008 when i have done grinds in the past i have put the wheel in a vice via the end of and axle , so when you girnd the rim, the wheel turns with it so it gives a nice smooth finish!that way gives you a crap grind, not ridged enough and is too smooth!you need to put a fair bit of pressure down on the rim!so do it as advised Boss!Ben Quote Link to comment Share on other sites More sharing options...
