Stems
ogre
killed my stem today (som shity viz cnc jobby) i have no idea about what stem to replace it with, currently got a koxx levelboss, so what stem should i go for? (geometry wise) what are the pros/cons of long+short or high/low stems.
Its all preference really, seeing as with that frame you can run any stem, its only high bb frame where your limted to high stems really. It just depends on high you like your front end ect. If you like a low front end stick with that or if you like a high front end which all the pros seemed to be going for these days then go for that. If you just fancy a change by going high/low front end may be find a cheap stem on here and if you like it stick with it or buy a new one that geo or similar if you dont then just get a new one like you old one.
Edited by basher
