Polyurethane Compund?
ConnorPowell
7mm thick
and aobut 10cm by 10cm
not 7mm thick, wouldnt leave you with much pad after its been put in a backing.
just get a backing measure the width lenght and depth ( add the depth to how much pad you want to stick out aorund 8mm and youve got your thickness) and then you can work out all the dimensions you need. Be alot more accurate than asking on here and getting answers off top of peoples heads.
