The Stig Posted November 9, 2007 Report Share Posted November 9, 2007 Ok i have a rear fixed hub with built in tensioner and is bloody amazing but won't stay in place and keep moving up anyone know how to sort it?? I thought a washer might do it?? any thoughts welcome?Tom Quote Link to comment Share on other sites More sharing options...
Mike W Posted November 9, 2007 Report Share Posted November 9, 2007 Try putting a serated washer on it to give it a bit more grip on the axel/frame. Quote Link to comment Share on other sites More sharing options...
The Stig Posted November 9, 2007 Author Report Share Posted November 9, 2007 Hmmmmm i will try and find soemthing tomorrow cus at the moment it is being pushed up and every so often it slips and well tis quite dangerous!! Quote Link to comment Share on other sites More sharing options...
blaze_ Posted November 10, 2007 Report Share Posted November 10, 2007 That's why I got rid of mine and put a normal derailleur. If anybody sorts it out please tell how because the tensioner is really nice, because of its weight. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted November 10, 2007 Report Share Posted November 10, 2007 http://www.observedtrials.net/vb/showthread.php?t=32319"From Webcyclery's website:'This rear hub has a built-in chain tensioner that's similar to the old Echo chain tensioner in that, honestly, we don't trust it entirely. Some aggressive riders have told us they have trouble with it slipping. Be among the first to try this hub and then let us know how it works. '" Quote Link to comment Share on other sites More sharing options...
Greetings Posted November 10, 2007 Report Share Posted November 10, 2007 If you're tensioning the chain upwards, I suggest you use a long ziptie to tie it to the top tube on the frame. Or just use a wire for that if the ziptie gets in the way of the chain.I'd also try using a file to create sharp notches on the part that rests against the frame. Quote Link to comment Share on other sites More sharing options...
Tom3bar Posted November 11, 2007 Report Share Posted November 11, 2007 I have one, it's pretty horrible !It just coming loose all the time. for now i put my old DA-BOMB tensioner, working f-i-n-e!But a solution is needed, bcs it's very nice that it is BUILT Inside the wheel...Tom Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted November 11, 2007 Report Share Posted November 11, 2007 I don't know what you boys are doing wrong... I've had mine for over a month and it hasn't moved once, only had to re-tension it due to chain stretch. However, if you do still have issues one of the guys on OTN drilled and tapped two grub screws through the tensioner which he locks down onto the axle after setting the position. Worked for him.Dave Quote Link to comment Share on other sites More sharing options...
The Stig Posted November 15, 2007 Author Report Share Posted November 15, 2007 Thanks guys!! well i managed to get a rear mech off cris so tis all good but will manage one day to sort it Quote Link to comment Share on other sites More sharing options...
