Final Cut Pro Help
Janson
hello.
my camera shoots in anamorphic widescreen. ie same res but different pixel aspect ratio.
i have successfully created an anamorphic project in fcp 5. when i export it it comes out in 4:3, which kind of sucks.
is there a way to get the pixel aspect ratio right. does mpeg even support non-standard pixel aspect ratios?
help me.
anamorphic stuff is more of a real-life video thing so I wouldn't be surprised if you had difficulty with formats (or players for that matter) supporting it.
have you tried outputting a quicktime instead?
if that doesn't work your best fix is probably to stretch in FC and output a square pixel movie - that's all the playback would do anyway.
