Cambelt Stripped
dirtbiker
Hey all,
Last night I managed to strip the cambelt teeth on my Seat Ibiza 1.4 and I was wondering if anyone has any idea how much damage there's likely to be (all my tools are at home in Southampton and I'm at uni in Nottingham so I can't have a look at the moment!)
Basically what happened is I stopped at some traffic lights and the revs fell straight to zero. Tried turning it over a few times but no luck (obviously). I'm guessing that there will have been some valve-piston contact but is this likely to have damaged the pistons or just bent the valves?
If I can get away with replacing the valves or the head than that's probably cost effective but I'm not sure I can justify an engine swap (as its the base model anyway so no electical goodies, which I'd like!)
Any thoughts until I get my tools up here to see for myself?
if it was at low revs, which by the sounds of it it was, you may be lucky and get away with little damage
if its at higher revs, then theres a strong possibility youve bent valves, chance of piston damage to beyond usability(there may be a small surfact indent, but thats pretty rare) is extremely unlikely. may find camshaft brackets have cracked. but yes, pretty sure youll get away with just a top end rebuild.
hell, dispite having owned a 1.4 seat ibiza(n reg) im not aware wether its an interference engine or not, hell if it aint, whack a new belt on, time it up, and drive it away.
