N Roach Posted November 2, 2007 Report Share Posted November 2, 2007 (edited) hey,Since putting anti-freeze into my magura, It has become very sluggish on the lever. I am thinking to just have a plain water bleed as I had no problems before. I have tried using a pump to clear out the internals of the brake but still sluggish. Anyone had this problem before and managed to sort it? Or any good tricks to free up the pistons? Greece, GT85 etc.Nathan Edited November 2, 2007 by chocolate_bikes Quote Link to comment Share on other sites More sharing options...
James Quigley Posted November 2, 2007 Report Share Posted November 2, 2007 3-in-1 Scilicon Lubricant (like wd40 I guess)Just pull out the piston with some pliers and squirt some around it. Quote Link to comment Share on other sites More sharing options...
N Roach Posted November 2, 2007 Author Report Share Posted November 2, 2007 3-in-1 Scilicon Lubricant (like wd40 I guess)Just pull out the piston with some pliers and squirt some around it.Does'nt the brake dirt clog on the oil on the pistons?What about the lever piston? Quote Link to comment Share on other sites More sharing options...
James Quigley Posted November 2, 2007 Report Share Posted November 2, 2007 Clean the cylinders then squirt, it'll be fine.As for the lever I take the hose and grub screw out, poke the piston out of the lever body with a spoke (through the hole where the grub screw was) clean everything with water and a lot of kitchen towel. Then stretch the old spring, douse the 'plunger'/piston and lever in lubricant replace spring and poke in plunger. Reassemble lever with hose and blade then bleed. That's what I do anyway.Oh and I dont use anti-freeze with my water bleed (never really gets cold enough to freeze down here). Quote Link to comment Share on other sites More sharing options...
liam-pantera Posted November 3, 2007 Report Share Posted November 3, 2007 Because you have put antifreze in your brake the antifreze will foam up inside the brake thats allways what happend to em so i jsut use water now . Quote Link to comment Share on other sites More sharing options...
padarik Posted November 3, 2007 Report Share Posted November 3, 2007 Because you have put antifreze in your brake the antifreze will foam up inside the brake thats allways what happend to em so i jsut use water now .wouldnt you need air in the system for it to foam up? never happend in past 2 years iv been running anti freeze and water Quote Link to comment Share on other sites More sharing options...
T.McMillan Posted November 3, 2007 Report Share Posted November 3, 2007 the antifreeze shouldnt foam up like "padarik" said you will need air in it to make it froth or bubble Quote Link to comment Share on other sites More sharing options...
liam-pantera Posted November 3, 2007 Report Share Posted November 3, 2007 yh your right you do but theres allways tiny amounts of air in the brakes . Quote Link to comment Share on other sites More sharing options...
padarik Posted November 3, 2007 Report Share Posted November 3, 2007 yh your right you do but theres allways tiny amounts of air in the brakes .ahh see what you mean. bath bleed, best way Quote Link to comment Share on other sites More sharing options...
liam-pantera Posted November 3, 2007 Report Share Posted November 3, 2007 ahh see what you mean. bath bleed, best way yep beth bleeds are awsome but my prefered method for bleeding a 2005 magura is to remove the lever and bleed is seperate (Y( Quote Link to comment Share on other sites More sharing options...
Jason222 Posted November 4, 2007 Report Share Posted November 4, 2007 Sounds kinda like you've got air in the system. Quote Link to comment Share on other sites More sharing options...
