"short" Chains, Sprocket Compatibility Etc.
Greetings
1) Are there any chains that are ~0.5% shorter than KMC chains?
2) Is there a way of getting a normal bmx sprocket onto the Dengomatic splined interface?
3) Any experience with the new Deng 135mm hubs with integrated mechs? Difficult to land on/bend? Do they have a spring or are they just squeezed by the frame and bearings?
4) Roughly how loose will a chain be on a 18:15 gear ratio with 375mm chainstays? Can the chain be tensioned upwards?
5) Don't suggest halflinks, I value my teeth and face.
Edited by Inur
KHE Collapse, when new.
Unsure, you can bodge a Profile one on though (not recommended)
Seem good, fixed/squeezed.
Possible up tension when new, probably not when chain has been used.
Good :)
Ads
