Stem And Brake Booster Questions
nickmpower
How does stem length change the way the bike handles? it seems like it might be easier to transfer weight back with a shorter stem?
Also if i buy a brake booster made for my magura hs22 brakes is it going to come with the longer bolts or am i going to need to buy those seperatly? Is it going to help my braking ability or just decrease the throw?
also what handle bars do you guys recommend? I have a monty now and dont really like the way it angles, or is this better for trials?
Edited by nickmpower
HI
your question on stems is corect the short the stm u have the easier it is to pull up the bike , this is because the wheelbase is shorter also the higher your bb the higer the stem u need.
for your brake any booster that is 4 bolt will come suplied with longer bolts and spacers .
anymore questions feel free to pm me .
I actaully have a longer stem, like 100mm(its the center to center distance of the holes right?. Im wondering what the advantage is to a longer one?
more leverage/bigger cockpit so you have more room to move around in?
