echoboy Posted October 28, 2007 Report Share Posted October 28, 2007 Looked at them on tartys but it did'nt say what they were for. Just wondered. if you know tell me please. Quote Link to comment Share on other sites More sharing options...
N Roach Posted October 28, 2007 Report Share Posted October 28, 2007 they are chain tensioners Quote Link to comment Share on other sites More sharing options...
chrisbikefix Posted October 29, 2007 Report Share Posted October 29, 2007 they are a Eccentric chain tensioner. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted October 29, 2007 Report Share Posted October 29, 2007 Surely if you found them on Tarty' you would've clicked ' Chain Tensioners 20" ' then saw the Snal Cams? Quote Link to comment Share on other sites More sharing options...
koxx20 Posted October 30, 2007 Report Share Posted October 30, 2007 Baisically you put them on your backwheel on the axel,there is little bolts that you screw into your frame to push against.Once the snail cam is installed correctly, you then push on the snail cam till you find the right tension of your chain then tighten your axel bolts back up. Your chain should stay tight but chains do stretch slightly. Quote Link to comment Share on other sites More sharing options...
Sonny Clarke Posted October 31, 2007 Report Share Posted October 31, 2007 Chain tensioners for mods lee you noob! Quote Link to comment Share on other sites More sharing options...
