Fixed Hub Or Freehub?
echoboy
It's what you prefer, more weight at the back or more weight in the middle. You can't feel the difference by having a freewheel at the back to having one at the front, so anybody telling you to get a front freewheel or a rear freehub because 'its better m8' will be lying to you. I use front freewheel because it's what I've always used, I'm sure alot of people will agree you can't beat an Eno for strength and reliability.
Frankly, it's all down to how minted you are. Both work in exactly the same way and are just as reliable as each other. The only difference is that freehubs are much more expensive. So, if you have a load of dosh and want that extra pimp factor, go for a freehub, but if you only have £40 to hand, run a freewheel.
In Estonia many people including myself have ordered our kings from aspire. Taxes can be dealt with - there will be none. I can see two options for serious trials: HD CK or Pro 2 trials.
Edited by Ints
