Laptop Problems!
Mike Beck
Hey,
in a bit of a pickle with the comp, i put a cd in the drive, can hear it starting to read the disk and spin it around a bit, then i wait for it come up on iTunes - NOTHING! Open the drive again, blow the disk, put it back in, open my computer, and theres no cd drive shown at all!! :blink:
im not a comp whizz but i know that there should be a CD drive up in my computer even when theres no cd in.
Someone help me, i want muse, foo fighters and stereophonics on my ipod :( !!!!
cheers lewis
when did the problem start? The first thing you could try is a systme restore, which basically takes your computer back in time to a certain point and restores it to those settings, you'll often find this fixes most menial problems, that is if infact, the problem is software or driver based. Anyway, to perform this:
Start > All programs > Accessories > System tools > System restore.
It will then ask you what date you would like to restore back to, so just to be on the safe side make it a day or two before you started noticing the problems if it gives you the options. It gives you the options of days when the last system checkpoint was created.
The second option I would suggest that is slightly more drastic is to re-install the drivers, which might work. and if it doesnt i believe you can always just perform a system restore and it will reset everything. (i will point out im not entirely confident with this procedure as im no i.t whizz so if its the wrong idea someone please say so this guy doesnt ruin his laptop more lol)
To do this go to Start > Control panel > System > Hardware > Device Manager
then you should see a list of things, open the one thats named IDE ATA/ATAPI controllers
then you should see two atleast two things, the Primary IDE channel and the secondary IDE channel.
right click them both and check the 'properties' to see if theres anything out of the ordinary, if not right click them and uninstall.
I think the computer will then promt you to re-boot and then it should automatically re-install the drivers for you. if not, do the restore like i said.
anyways, hope these work for you and arnt complete rubbish lol.
J
