Echo 6spd Fixed Rear Hub....can I Change The Bearing's?
hugh_b
I should think it is possible. If so it will be a case of take any spacers or end caps off first and then give the non diveside of the axel a bash with hammer this willforce the axel out and the bearing out of the driveside. Then take the axel out and with a socket or something knock the non driveside out.
