PaRtZ Posted October 19, 2007 Report Share Posted October 19, 2007 Basically, im not distrusting the adam @ tarty, but their site says its only compatible with monty + tryall setups. Im *hopefully* going to be running the SKF 300 (£43 one) with echo CNC cranks + an ENOWill it blend? or scratch my hydroxx mod alot?Thanks in advance Quote Link to comment Share on other sites More sharing options...
muddyfox Posted October 19, 2007 Report Share Posted October 19, 2007 (edited) The problem would be the tabs on the eno will rub on the bb cup, unless you grind them down Edited October 19, 2007 by muddyfox Quote Link to comment Share on other sites More sharing options...
ben_travis Posted October 19, 2007 Report Share Posted October 19, 2007 partz.i got a truvativ gigapipe bb from adam, and he measured the fit with the following set up and it came out with like 0.25mm clearance. its working nicely, but i think u will have trouble wiht your eno.czar cranksczar bashecho freewheeltruvativ gigapipe bb Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted October 19, 2007 Report Share Posted October 19, 2007 The issues with the ENO (and all other FWs with sticky-outy tabs) is that the bore isn't large enough to clear the axle stop on the SKF BB. Of course you could machine down the stop but we dont recommend this...The freewheels with 'inny' tabs (Try-All, Monty) have a large enough bore to pass over the SKFs axle stop so they usually work, always if you have no bashring on your cranks Quote Link to comment Share on other sites More sharing options...
