Hope Disk Problem
monty boi
Remove the lever, inspect for any cracked parts or general wear...
Are the calipers moving in or signs of leaking anywhere? If so it'll probably be sucking air into the system and it will not work....or air in the system from the bleed and your simply trying to compress an air bubble...try a good re-bleed...check pipes, bolts, connections for any oil.
Failing that, contact Hope, they appear to have exellent customer service and will no doubt ask to inspect the brake; they'll either fix it (possible cost) or replace it (possible cost)...
...but usually a good bleed sorts everything out :)
i would say get rid of the hope they are crap and always do this, get a bb7 or better still dont use a disk.
Na disk are the best they always hold even in the wet
My brake does that when the bike is upside down but all i have to do is pump it and it gets back to normal
