gr8grumble Posted October 17, 2007 Report Share Posted October 17, 2007 i installed a brand new set of CNC coust pads.... they are silent rolling forward... but backwards there loud as hell..any ideas? i want it to be noisy when i roll forward... not backwards! i reground my rim, and set it up well good.the grind is ever so slightly slanted, could that be the reasson?any ideas lads?gray Quote Link to comment Share on other sites More sharing options...
26inch Posted October 17, 2007 Report Share Posted October 17, 2007 (edited) why do you want your pads to be noisy? aslong as they bite and hold well thats all that matters Edited October 17, 2007 by 26inch Quote Link to comment Share on other sites More sharing options...
gr8grumble Posted October 17, 2007 Author Report Share Posted October 17, 2007 They dont hold, and they dont bite! Quote Link to comment Share on other sites More sharing options...
Fixed Pants™ Posted October 17, 2007 Report Share Posted October 17, 2007 (edited) Flip the pads over? Grind with the grinder pointing towards the back of the bike slightly?EDIT: Deffo grind again, probably best to keep it exactly upright or it won't hold going backwards. Edited October 17, 2007 by Fat Pants Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted October 17, 2007 Report Share Posted October 17, 2007 if you grind clockwise on both sides of the rim then you'll get hold and bite whilst going forward aswell as backwards hope this helps,steve Quote Link to comment Share on other sites More sharing options...
gr8grumble Posted October 17, 2007 Author Report Share Posted October 17, 2007 if you grind clockwise on both sides of the rim then you'll get hold and bite whilst going forward aswell as backwards hope this helps,stevewe will see if it helps. im off to do that right now. Quote Link to comment Share on other sites More sharing options...
Muel Posted October 17, 2007 Report Share Posted October 17, 2007 Take the rim off and turn it round and turn the pads round. Quote Link to comment Share on other sites More sharing options...
Janson Posted October 17, 2007 Report Share Posted October 17, 2007 the whole difference between "backwards" and "forwards" grinds is bullshit. it's an angle grinder, not rocket science. Quote Link to comment Share on other sites More sharing options...
JonMack Posted October 17, 2007 Report Share Posted October 17, 2007 Take the rim off and turn it round and turn the pads round.Probably a lot easier to regrind than dismantle the wheel and rebuild it. Quote Link to comment Share on other sites More sharing options...
gr8grumble Posted October 17, 2007 Author Report Share Posted October 17, 2007 Im sort of getting there.. ive got a tiny bit of noise, but loads of "swoooosh". ill keep tryin to bed them in, it just feels like they have barely any bite Quote Link to comment Share on other sites More sharing options...
Ryan Blackwell Posted October 17, 2007 Report Share Posted October 17, 2007 Try bedding them in mate.Are you running a booster?Mine are loud somtimes and somtimes not lol. Quote Link to comment Share on other sites More sharing options...
gr8grumble Posted October 17, 2007 Author Report Share Posted October 17, 2007 Try bedding them in mate.Are you running a booster?Mine are loud somtimes and somtimes not lol.yea mate, a toxsin 2bolt.ill try bedding it in loads..just dont wanna bed em in... then they never get lud, that'll f**k me off. lolgray Quote Link to comment Share on other sites More sharing options...
Greetings Posted October 17, 2007 Report Share Posted October 17, 2007 This usually happens when the pads are not parallel to the rim. Also, try cleaning the rim and pads with nitro thinner. Quote Link to comment Share on other sites More sharing options...
gr8grumble Posted October 17, 2007 Author Report Share Posted October 17, 2007 This usually happens when the pads are not parallel to the rim. Also, try cleaning the rim and pads with nitro thinner.ok. Quote Link to comment Share on other sites More sharing options...
gr8grumble Posted October 17, 2007 Author Report Share Posted October 17, 2007 went out for a lil ride to bed them in..... there actually terrible. i have never had this problem before.. i cant understand why!? Quote Link to comment Share on other sites More sharing options...
Ash-Trials Posted October 17, 2007 Report Share Posted October 17, 2007 What pads are you rinning?Aslong as pads are parrelell(sp?) to rim and grind is good they should hold awesome i give pads a day to bed in.Ash~ Quote Link to comment Share on other sites More sharing options...
gr8grumble Posted October 17, 2007 Author Report Share Posted October 17, 2007 CNC coust pads.. and they hit flat n square and all that.. Quote Link to comment Share on other sites More sharing options...
Ash-Trials Posted October 17, 2007 Report Share Posted October 17, 2007 no idea.If pads are clean. mabie rim but i dont see how they dont work good. Quote Link to comment Share on other sites More sharing options...
El Cristoff Posted October 17, 2007 Report Share Posted October 17, 2007 take your booster off, that should work. Quote Link to comment Share on other sites More sharing options...
gr8grumble Posted October 17, 2007 Author Report Share Posted October 17, 2007 take your booster off, that should work.Tried that. Performed the same. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted October 17, 2007 Report Share Posted October 17, 2007 its defo your grind technique Quote Link to comment Share on other sites More sharing options...
gr8grumble Posted October 17, 2007 Author Report Share Posted October 17, 2007 how do you suggest i grind it? Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted October 17, 2007 Report Share Posted October 17, 2007 Ok this happens to me alot....what i do is clean the rim with lighter fluid.do the same with the padsflip the pads round and drag on and off down hill for about 3 mins..........that always sorts it out for me.......but as long as a pad holds well enough thats all that should really matter.....i know people thees days purchase pad for the so called SOUND and not based on performanceect ectdave Quote Link to comment Share on other sites More sharing options...
gr8grumble Posted October 17, 2007 Author Report Share Posted October 17, 2007 Ok this happens to me alot....what i do is clean the rim with lighter fluid.do the same with the padsflip the pads round and drag on and off down hill for about 3 mins..........that always sorts it out for me.......but as long as a pad holds well enough thats all that should really matter.....i know people thees days purchase pad for the so called SOUND and not based on performanceect ectdavei will try that, have some lighter fluid round here somewhere.thing about the sound is.... normally.. when it makes loadsa noise, it has loadsa bite...has none, and i dont feel safe...??!!lolgraham,.. Quote Link to comment Share on other sites More sharing options...
Si-man Posted October 17, 2007 Report Share Posted October 17, 2007 riding with water/ muc off on the rim and holding the brake used to make the brake bite like f**k!That was with koxx browns though. shouldnt really be any different. Quote Link to comment Share on other sites More sharing options...
