Hi About Heatsink Coust Pads
maty-trials
Really good pads, I would suggest using these pads on a harder rim such as an echo 07, but they work exceptionally well on a tryall rim with a lite sharp grind. Any rim will work, just experiment with different grinds and see which works best for your rim!
once you have bought them all your brake problems will go away. suitable for any type of grind. the harsher it is the less they will probably last. but thats just commen sense lol.
matt
they have the same wear rate as koxx browns in my opinion, which is bloody long
