Headset Problems
ConnorPowell
Well im having problems with my canecreek c2 headset, the problem is that it is costentantly loose and knocking back a forth. i seem to think that i have something missing, or that im not putting it together right, so has anyone got a diagram that shows the correct way it goes and all of the bits needed please.
Thanks connor
Is it tightening up and then being loose as you ride? Or loose straight away?
As they're cartridge bearings, you should only have the bottom cup, top cup and the cap to sit on the stem...If I remember rightly? As ash said, make sure the top of your fork steer tube isnt reaching the stem cap, otherwise it's impossible to tighten up...and so you'll have to cut your steer tube down a bit.
Do you not have a 'C' shaped ring with the headset? I know with the hope on you have a ring that sits into the top bearing and stablises the tube from movement...
