Czar Parts
koxxtrials
anything missing out of this for my new mod coming soon
Czar short disc frame £299
Hope mono trial 160 mm front right hand £135 avid juicy 3 £50
Echo front disc hub black & 116mm echo fixed 20’’ disc black, 12t sprocket £145
Echo lite fork disc only £70
Echo 6061 forged 160mm Isis cranks pair £52
Gusset prosecuter pedals £15
Tensile freewheel £35
Try-all front and rear rims fluro green no sidewalls/ just green 32 h front 36h rear £70
Cane creek C2 £20
Monty 221 ti stem (31.8mm) £74
V! Z maxbar black £45
Maxxis creepy crawler tyres pair (19, 20’’) £31
Gusset b*****d grips green £7
Kmc k710 kool 1/8’’ £12
Mutiny plain gauge 19, 20’’ (black) with nipples Hubs: echo front disc, echo fixed 20’’ disc Rim: try-all Hole: 32h front 36h rear £10
echo Isis bottom bracket £45
Pro-bolt m6 x 20 titanium (6) (stem clamps, disc brake calipers) £24
Echo, zoo, czar, gu, adamant hub axle bolts ( 2 pairs) £12
Onza stainless chainring 20t £15
Onza hose clip x4 £4 (if the frame doesn’t come with hose clips)
Monty snail cam tensioners £6
Hope torx rotor bolts £3
Maxxis welterweight inertube £10
f**k rear disk off, its not as good as a maggie has a horrible feel i think. And save yourself abit of money and get 221pro bars instead of viz ones. Also f**k the pro bolts off.
Your sort of right, apart from the bit about rear disc, which is clearly the future.
Yeh but get PR bars, not pro, it says PR.
Max Bars rule! Sooo stiff, i'm never running Deng bars unless i have to ever again.
36h rear rim and 32h hub?
Strange setup, Ti bolts but forged cranks?
And why do you need axle bolts?
I would consider buying some others parts else where, as in bb, grips, tyres, pedals...
Also why a 20t cog on top of it all?
do you mean the chainring its really complicated to put a parts list together i have changed a few bits and if you don't have axle bolts what do you need and the titanium pro bolts don't hold as a axle bolt
Edited by koxxtrials
Right,
the rear hub will come complete with a 12t fixed cog and axle bolts already, you just need a rim and spokes. 32h!
the cranks will need just a freewheel and bashguard.
the bottom bracket will come with axle bolts already.
all parts include nuts/bolts and fixings, no more is needed. ti bolts are only needed if you want to shave some extra weight.
personnally i wouldn't bother buying ti bolts if your running heavier parts anyway.
all clear?
