chris slater Posted October 6, 2007 Report Share Posted October 6, 2007 Does anybody know what is the best tire pressure to run in the back tire off my T-mag?Cheers Chris.. Quote Link to comment Share on other sites More sharing options...
Sir_Hops_Alot Posted October 6, 2007 Report Share Posted October 6, 2007 (edited) Whateva feels comfortable for you mate. It's all done to your own preference. Edited October 6, 2007 by Chris_J Quote Link to comment Share on other sites More sharing options...
Broomer Posted October 6, 2007 Report Share Posted October 6, 2007 Tyre. Quote Link to comment Share on other sites More sharing options...
J Trials 31 Posted October 6, 2007 Report Share Posted October 6, 2007 25-35 PSI probably. I run 20-25 in the front so a little bit more in the rear. Quote Link to comment Share on other sites More sharing options...
=)zoo python Posted November 20, 2007 Report Share Posted November 20, 2007 I just pump mine up to about 35 psi (front and back) then when i go out on a ride i just them down a bit until i find a perfect pressure. Quote Link to comment Share on other sites More sharing options...
joshball Posted November 21, 2007 Report Share Posted November 21, 2007 Just pump it up until it fells good!If its too hard then let some air out!Simple!Echo.JoshX-x-X Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted November 21, 2007 Report Share Posted November 21, 2007 well im around 10 stones in weight and run 9 psi in the front and 15 in the rear..... Quote Link to comment Share on other sites More sharing options...
Der Flo Posted November 21, 2007 Report Share Posted November 21, 2007 hej,i would say the tire pressure depends on your "skills". if you don't drive for a while it is better to run your backwheel with enough pressure to save your rim.it depends also on the things you want to do. if you allways drive on rails you need enough traction so you must run on low pressure.an other point ist that you must look at your weight.so test it in some trainings and you get to know which pressure is the best for you.in my sight it is important that you don't run it to low. (but i don't like to fix it every day )flo Quote Link to comment Share on other sites More sharing options...
Jaffacakes Posted November 21, 2007 Report Share Posted November 21, 2007 Just have it as low as you can without killing inertubes and wheels. low pressure = grip.High pressure = sliding in the wet and bouncing off things. Quote Link to comment Share on other sites More sharing options...
Si-man Posted November 21, 2007 Report Share Posted November 21, 2007 Im sure there will be about 400 topics if you search.TYRE aswell. your not american Quote Link to comment Share on other sites More sharing options...
Oli Smith Posted November 21, 2007 Report Share Posted November 21, 2007 id dont run my tyres on any precise pressure I just run them on what feels right. natural a little soft.................and street probably pretty hard if u wanna do gaps. drops, n taps... Quote Link to comment Share on other sites More sharing options...
