Jsy ben R Posted October 6, 2007 Report Share Posted October 6, 2007 i gt hs33 and need help please Link to comment Share on other sites More sharing options...
Muel Posted October 6, 2007 Report Share Posted October 6, 2007 That is the shittest topic ever, that not only makes no sense but doens't tell anyone what the f**k is wrong!Christ your asking for help, at least tell us what with. Link to comment Share on other sites More sharing options...
MadManMike Posted October 6, 2007 Report Share Posted October 6, 2007 Coming Soon:Y int eye valedaytid yt? Link to comment Share on other sites More sharing options...
Muel Posted October 6, 2007 Report Share Posted October 6, 2007 Coming Soon:Y int eye valedaytid yt?Mike, your a legend.I have already been warned for pre-member bullying, but surely, even Tomm bullies the pre-member in question in this situation? Link to comment Share on other sites More sharing options...
Trix Posted October 6, 2007 Report Share Posted October 6, 2007 Well usually, when braking and I believe most will agree to use one finger in Trials so you have more grip on your handlebars, when you need to use your highly sophisticated hs33, you must pull your lever in with your index finger. Remember the lever is attached to the left hand side of the handle bars. Pull the lever in with your index finger in in till you feel the pads hit the rim then they will start slowing you down, the more you pull in the more violently your bike will stop.Now another tricky bit, how to get the brake to stop braking? Well once you have come to your desired position and speed if any using your HS33 you must now release the lever you do this by lifting your index finger off of the lever, the highly sophisticated hs33 will respond by taking the pads off your rim now you can move again. So remember. To StopIndex finger at the ready on leverPull index finger in to slowdown / stop the bikeTo move againlift index finger off brake lever modulate for your desired movementonce raised off you can goPlease feel free to put this in the Wiki How toosHope I have helped Link to comment Share on other sites More sharing options...
Muel Posted October 6, 2007 Report Share Posted October 6, 2007 Well usually, when braking and I believe most will agree to use one finger in Trials so you have more grip on your handlebars, when you need to use your highly sophisticated hs33, you must pull your lever in with your index finger. Remember the lever is attached to the left hand side of the handle bars. Pull the lever in with your index finger in in till you feel the pads hit the rim then they will start slowing you down, the more you pull in the more violently your bike will stop.Now another tricky bit, how to get the brake to stop braking? Well once you have come to your desired position and speed if any using your HS33 you must now release the lever you do this by lifting your index finger off of the lever, the highly sophisticated hs33 will respond by taking the pads off your rim now you can move again. So remember. To StopIndex finger at the ready on leverPull index finger in to slowdown / stop the bikeTo move againlift index finger off brake lever modulate for your desired movementonce raised off you can goPlease feel free to put this in the Wiki How toosHope I have helpedLMAO! A Wiki on "How to operate your brakes", that would be class. Link to comment Share on other sites More sharing options...
Trix Posted October 6, 2007 Report Share Posted October 6, 2007 (edited) i gt hs33 and need help please Please in future be more specific, ask stupid questions your get stupid answers, and yes I am bored. Edited October 6, 2007 by Trix Link to comment Share on other sites More sharing options...
Jsy ben R Posted October 7, 2007 Author Report Share Posted October 7, 2007 soz nt fought out properley i need help on how to bleed brakes Link to comment Share on other sites More sharing options...
ConnorPowell Posted October 7, 2007 Report Share Posted October 7, 2007 Yh Blud, what u gt 2 do iz read da booklet that come wid da brakes wen u bought it. Link to comment Share on other sites More sharing options...
Trix Posted October 7, 2007 Report Share Posted October 7, 2007 (edited) You made a topic about how to bleed brakes before on the 4th of October, its not the best how to but you can learn how to do it by reading the last post in your topic...YOUR TOPICFailing that look at the website, at the top it says Wiki there are lots of how tos so on WIKI Edited October 7, 2007 by Trix Link to comment Share on other sites More sharing options...
neomember Posted October 7, 2007 Report Share Posted October 7, 2007 (edited) Well usually, when braking and I believe most will agree to use one finger in Trials so you have more grip on your handlebars, when you need to use your highly sophisticated hs33, you must pull your lever in with your index finger. Remember the lever is attached to the left hand side of the handle bars. Pull the lever in with your index finger in in till you feel the pads hit the rim then they will start slowing you down, the more you pull in the more violently your bike will stop.Now another tricky bit, how to get the brake to stop braking? Well once you have come to your desired position and speed if any using your HS33 you must now release the lever you do this by lifting your index finger off of the lever, the highly sophisticated hs33 will respond by taking the pads off your rim now you can move again. So remember. To StopIndex finger at the ready on leverPull index finger in to slowdown / stop the bikeTo move againlift index finger off brake lever modulate for your desired movementonce raised off you can goThis should be sticky!!I used to stop with my shoes but now i'm gonna put my helmet and definitely try this!Will this work for disc brakes??? Edited October 7, 2007 by neomember Link to comment Share on other sites More sharing options...
Token Posted October 7, 2007 Report Share Posted October 7, 2007 These are my favourite topics. Now please, everyone, bully him. Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted October 8, 2007 Report Share Posted October 8, 2007 Well usually, when braking and I believe most will agree to use one finger in Trials so you have more grip on your handlebars, when you need to use your highly sophisticated hs33, you must pull your lever in with your index finger. Remember the lever is attached to the left hand side of the handle bars. Pull the lever in with your index finger in in till you feel the pads hit the rim then they will start slowing you down, the more you pull in the more violently your bike will stop.Now another tricky bit, how to get the brake to stop braking? Well once you have come to your desired position and speed if any using your HS33 you must now release the lever you do this by lifting your index finger off of the lever, the highly sophisticated hs33 will respond by taking the pads off your rim now you can move again. So remember. To StopIndex finger at the ready on leverPull index finger in to slowdown / stop the bikeTo move againlift index finger off brake lever modulate for your desired movementonce raised off you can goPlease feel free to put this in the Wiki How toosHope I have helped*applause* for thoroughness and time spent on that These are my favourite topics. Now please, everyone, bully him. Yar, yar. Link to comment Share on other sites More sharing options...
wingsalumini Posted October 8, 2007 Report Share Posted October 8, 2007 harsh yet amusing, i agree a round of applause is in order? Link to comment Share on other sites More sharing options...
neomember Posted October 9, 2007 Report Share Posted October 9, 2007 *Bump* Link to comment Share on other sites More sharing options...
cadbury's cream egg Posted October 9, 2007 Report Share Posted October 9, 2007 Well usually, when braking and I believe most will agree to use one finger in Trials so you have more grip on your handlebars, when you need to use your highly sophisticated hs33, you must pull your lever in with your index finger. Remember the lever is attached to the left hand side of the handle bars. Pull the lever in with your index finger in in till you feel the pads hit the rim then they will start slowing you down, the more you pull in the more violently your bike will stop.Now another tricky bit, how to get the brake to stop braking? Well once you have come to your desired position and speed if any using your HS33 you must now release the lever you do this by lifting your index finger off of the lever, the highly sophisticated hs33 will respond by taking the pads off your rim now you can move again. So remember. To StopIndex finger at the ready on leverPull index finger in to slowdown / stop the bikeTo move againlift index finger off brake lever modulate for your desired movementonce raised off you can goPlease feel free to put this in the Wiki How toosHope I have helpedthat is one of the best things i have ever seen on trial forum ..wiki ***leon Link to comment Share on other sites More sharing options...
Alex@Flawless Bikes Posted October 9, 2007 Report Share Posted October 9, 2007 i gt hs33 and need help please Worst topic EVER! Link to comment Share on other sites More sharing options...
monty-james Posted October 9, 2007 Report Share Posted October 9, 2007 so thats why i always fall of when hitting corners at a great speed, thanks for the tip mate Link to comment Share on other sites More sharing options...
Token Posted October 10, 2007 Report Share Posted October 10, 2007 It's in the Wiki now. Find it here.God bless the 'special' people among us. Link to comment Share on other sites More sharing options...
james266 Posted October 10, 2007 Report Share Posted October 10, 2007 It's in the Wiki now. Find it here.God bless the 'special' people among us.I cant believe thats been added Link to comment Share on other sites More sharing options...
El Cristoff Posted October 10, 2007 Report Share Posted October 10, 2007 It's in the Wiki now. Find it here.God bless the 'special' people among us.you missed the more essential crank turn to get the bike going again, come on people, be more specific, or he'll be stuck on the spot wondering why his bikes not moving. Link to comment Share on other sites More sharing options...
Trix Posted October 10, 2007 Report Share Posted October 10, 2007 (edited) It's in the Wiki now. Find it here.God bless the 'special' people among us.oh my god """""!!!!!! I'm famous, this is cool, that link is going in my sig remember guys any other tips like how to move the bike around a corner i will gladley help...LoL This has seriously made my day, oh man my names not on the brakes how too Edited October 10, 2007 by Trix Link to comment Share on other sites More sharing options...
Sonny Clarke Posted October 11, 2007 Report Share Posted October 11, 2007 Here's a guide on hot to bleed your Magura HS33 hydrolic brakes:-Losen the TPA all of the way off.Move the whole lever up so that it's pointing forwards instead of down.Fill a syringe with water or oil, it's your choice but I like water better because it gives a better feel to the lever.Take the bleed bolt off of the slave cylinder.Use one of the clear tubes shown up there in the first picture and screw it into the bleed hole but make sure that the tube is full up with water before you screw it on. I find it easier to put the syringe on the pipe and fill the pipe with the syringe.Undo the little grub screw on the lever body pictured below;Take the other clear tube and screw it into that hole.Ask someone if they can hold an old butter tub or something under the plastic pipe coming from the lever otherwise you'll get oil all over your rim/rotor.Now that's all done up nice and tight pump the syringe until most of the fluid from it is gone. (Remember to go from the slaves to the lever!)Now look at the tube coming out of the lever, if it has air in you need to do that again. (When you take the syringe off of the pipe remember to get someone to put their finger over the other end. )When no more air comes out of the pipe then it's finished.Take the pipe off of the lever and put the grub screw back in but remember when you're taking the pipe off of the lever remember to leave the syringe on the pipe coming from the slave.Now take the pipe off of the slave and put the bleed bolt back in.[edit] Bleeding Maguras in a bucket or a bathFill the bucket or the bath full of water.Take the brake off of your bike and put it in the bucket/bath.Undo both bleed bolts, the one on the lever and the one on the slave. (Underwater)The method is tricky at first, but once you have the rhythm, it will take a minute at maximum.Underwater: hold your finger over the hole on the slave cylinder (remember, when you have your finger on the hole, make sure it is tight and sealed against the hole, other wise it will take longer to bleed and may effect performance), press the lever all the way down, take your finger off of the hole and release the lever fully, repeat until you no longer see any air coming out.Do up both of the bleed bolts. (Again, underwater)Take the brake out and it should be air free.Hope i helpd, Sonny Link to comment Share on other sites More sharing options...
Trix Posted October 11, 2007 Report Share Posted October 11, 2007 Here's a guide on hot to bleed your Magura HS33 hydrolic brakes:-Losen the TPA all of the way off.Move the whole lever up so that it's pointing forwards instead of down.Fill a syringe with water or oil, it's your choice but I like water better because it gives a better feel to the lever.Take the bleed bolt off of the slave cylinder.Use one of the clear tubes shown up there in the first picture and screw it into the bleed hole but make sure that the tube is full up with water before you screw it on. I find it easier to put the syringe on the pipe and fill the pipe with the syringe.Undo the little grub screw on the lever body pictured below;Take the other clear tube and screw it into that hole.Ask someone if they can hold an old butter tub or something under the plastic pipe coming from the lever otherwise you'll get oil all over your rim/rotor.Now that's all done up nice and tight pump the syringe until most of the fluid from it is gone. (Remember to go from the slaves to the lever!)Now look at the tube coming out of the lever, if it has air in you need to do that again. (When you take the syringe off of the pipe remember to get someone to put their finger over the other end. )When no more air comes out of the pipe then it's finished.Take the pipe off of the lever and put the grub screw back in but remember when you're taking the pipe off of the lever remember to leave the syringe on the pipe coming from the slave.Now take the pipe off of the slave and put the bleed bolt back in.[edit] Bleeding Maguras in a bucket or a bathFill the bucket or the bath full of water.Take the brake off of your bike and put it in the bucket/bath.Undo both bleed bolts, the one on the lever and the one on the slave. (Underwater)The method is tricky at first, but once you have the rhythm, it will take a minute at maximum.Underwater: hold your finger over the hole on the slave cylinder (remember, when you have your finger on the hole, make sure it is tight and sealed against the hole, other wise it will take longer to bleed and may effect performance), press the lever all the way down, take your finger off of the hole and release the lever fully, repeat until you no longer see any air coming out.Do up both of the bleed bolts. (Again, underwater)Take the brake out and it should be air free.Hope i helpd, Sonny LoL This Is Copied From WIKI Link to comment Share on other sites More sharing options...
MadManMike Posted October 11, 2007 Report Share Posted October 11, 2007 "Hope I helped" - you mean you hope your copied info helped lol... Link to comment Share on other sites More sharing options...
