Jsy ben R Posted October 4, 2007 Report Share Posted October 4, 2007 i have a set of maguera hs33 and people say to bleed them wid water is it a good idea thanks ben Quote Link to comment Share on other sites More sharing options...
Davetrials Posted October 4, 2007 Report Share Posted October 4, 2007 (edited) its a brilliant idea, it feels bettereasier to bleed, as ur not messing about with bloody maggie fluidif u bugger ur hose u can rebleed it anywere u want. Edited October 4, 2007 by Davetrials Quote Link to comment Share on other sites More sharing options...
max-t Posted October 4, 2007 Report Share Posted October 4, 2007 its a brilliant idea, it feels bettereasier to bleed, as ur not messing about with bloody maggie fluidif u bugger ur hose u can rebleed it anywere u want.Except for in the sahara desert. Then your f**ked Quote Link to comment Share on other sites More sharing options...
neomember Posted October 4, 2007 Report Share Posted October 4, 2007 Is this sarcasm? Quote Link to comment Share on other sites More sharing options...
Davetrials Posted October 4, 2007 Report Share Posted October 4, 2007 Except for in the sahara desert. Then your f**ked you could probly use pissand no its not sarcasim, ive been using water for about 4 years now, i refuse to use magura blood. Quote Link to comment Share on other sites More sharing options...
neomember Posted October 4, 2007 Report Share Posted October 4, 2007 Cool! Quote Link to comment Share on other sites More sharing options...
TrAsHeR Posted October 4, 2007 Report Share Posted October 4, 2007 Ill just give you some tips if you want to bleed it with water used deonised water ( i think ) used for iron because there is no mineral in it or you can use baby oil wich is also good between water and magura blood. And to make your bleed easier do it in a bath full of water so there will be no air in your brakes Good luck Quote Link to comment Share on other sites More sharing options...
Krisboats Posted October 4, 2007 Report Share Posted October 4, 2007 Ill just give you some tips if you want to bleed it with water used deonised water ( i think ) used for iron because there is no mineral in it or you can use baby oil wich is also good between water and magura blood. And to make your bleed easier do it in a bath full of water so there will be no air in your brakes Good luckMy syringe bleeds with normal tap water are always better than bath bleeds i try and do. Not to mention being easier and quicker. Quote Link to comment Share on other sites More sharing options...
Jsy ben R Posted October 5, 2007 Author Report Share Posted October 5, 2007 Cheers for all help so far Quote Link to comment Share on other sites More sharing options...
JaMmY Posted October 5, 2007 Report Share Posted October 5, 2007 water bleed is brillbetter than any other bleedand only takes a secin the bath or sink! Quote Link to comment Share on other sites More sharing options...
stuie Posted October 5, 2007 Report Share Posted October 5, 2007 i got bored at work the other day and thought im goin to bleed my breaks....i had nothing there, no bleed kit, no nothing and i drained the old fluid out by undoing the bottom bleed hole and pulling the lever, till all the fluid is out.then put you're magura underwater, take off the other bleed screw and (keeping the magura under water) put you're thumb over the lever bleed hole and pull the lever in, as you go to release the lever take you're thumb back off the hole. keep repeting this till there is no more air coming out of the bottom bleed hole. then replace the bleed screw's (with the whole break still under the water)hope this help's u. Quote Link to comment Share on other sites More sharing options...
