jonny6 Posted October 3, 2007 Report Share Posted October 3, 2007 how do you get the cable to go over the barbed bolt that screws into the piston housing ? My cable snapped just above it , ive cut the old bit off but i cant get the fresh bit over the barbed bolt . help me please !!Thanks guys ! Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted October 3, 2007 Report Share Posted October 3, 2007 Ideally you need the 2 hard plastic hose clamp thingys to hold the hose while you hammer the barb in. Quote Link to comment Share on other sites More sharing options...
Si-man Posted October 3, 2007 Report Share Posted October 3, 2007 cup of boiling water, dip it in for about 20 seconds or so, push like f**k until it goes on. Keep dipping it in if it doesnt go all the way on 1st time, just make sure you dont take the barb off for that. Dont scald yourself either. Quote Link to comment Share on other sites More sharing options...
jonny6 Posted October 3, 2007 Author Report Share Posted October 3, 2007 Ideally you need the 2 hard plastic hose clamp thingys to hold the hose while you hammer the barb in. oh ok , no other way of getting it in there ? tried heating the bolt up , big no no ! where would i get them from ?Thanks for replying by the way !cup of boiling water, dip it in for about 20 seconds or so, push like f**k until it goes on. Keep dipping it in if it doesnt go all the way on 1st time, just make sure you dont take the barb off for that. Dont scald yourself either. does that really work ? Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted October 3, 2007 Report Share Posted October 3, 2007 Read what si-man said mate. You'd need to buy an authentic magura bleed kit to get them. Quote Link to comment Share on other sites More sharing options...
jonny6 Posted October 3, 2007 Author Report Share Posted October 3, 2007 just tried that and it aint working !was pushing soooo hard ! how would a shop do it ? Quote Link to comment Share on other sites More sharing options...
d_c Posted October 3, 2007 Report Share Posted October 3, 2007 Ideally you need the 2 hard plastic hose clamp thingys to hold the hose while you hammer the barb in.The shop would use a proper magura kit!No other way of doing it that i know of, they usually split if you dont use them.Danny. Quote Link to comment Share on other sites More sharing options...
Si-man Posted October 3, 2007 Report Share Posted October 3, 2007 (edited) See the 2 white blocks, they are what you need, along with the boiling water. You also need a vice idealy so you can clamp it up. That kit is about £20 from what I remember, all you ever need really. there is a guide somewhere to bleeding if you don't know hoe to do it, just have a search in the FAQ section. Edited October 3, 2007 by Si-man Quote Link to comment Share on other sites More sharing options...
jonny6 Posted October 3, 2007 Author Report Share Posted October 3, 2007 cheers dude ! most helpful ! Quote Link to comment Share on other sites More sharing options...
Concussion Posted October 4, 2007 Report Share Posted October 4, 2007 I once used a BMX stem as a make shift plastic hose clamp thingy, I just clamped the hose close to the bolts and tightened the top of the stem on to it... not the best set-up in the world but it worked. But yeah, heat the tube with boiling water and tap the barbed bolt in `straight` with a hammer. If you get the first lip of the bolt in, just heat both some more and keep going. Quote Link to comment Share on other sites More sharing options...
Ste Wilson Posted October 4, 2007 Report Share Posted October 4, 2007 tartybikes sell the rim service kit with the blocks in http://www.tartybikes.co.uk/product.php?id=2074ste.. Quote Link to comment Share on other sites More sharing options...
