NVWOCI WVS Posted October 2, 2007 Report Share Posted October 2, 2007 im considering bunging one of these deore jobbys on the front of my mod, do you reckon it will take trials abuse? they look pretty smart and aparently give a stronger wheel build. anyone got any experience with them? it's only £17.50 on CHAIN REACTION CYCLES so it might be worth a try? Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted October 2, 2007 Report Share Posted October 2, 2007 how the hell does that work then ?Adam Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted October 2, 2007 Author Report Share Posted October 2, 2007 adamgriffin3 said: how the hell does that work then ?Adampoke your spokes in the keyholes i presume Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted October 2, 2007 Report Share Posted October 2, 2007 How would you benefit from that?I've never had any problems with my hub flanges...ever? Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted October 2, 2007 Author Report Share Posted October 2, 2007 Dan6061 said: How would you benefit from that?I've never had any problems with my hub flanges...ever? it's just something a bit different isnt it? and it might be absolutely amazing in some unexpected way!it's not a lot of money either so it might be worth a shot?! Quote Link to comment Share on other sites More sharing options...
ogre Posted October 2, 2007 Report Share Posted October 2, 2007 (edited) got a 32H rim? *had a well stupid moment + forgot rims came in 32H :$ * awww man, put me back in nmc? Edited October 2, 2007 by ogre Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted October 2, 2007 Author Report Share Posted October 2, 2007 ogre said: got a 32H rim?yes thanks, you? Quote Link to comment Share on other sites More sharing options...
Greetings Posted October 2, 2007 Report Share Posted October 2, 2007 I think you need spokes with a straight head for that hub. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted October 2, 2007 Report Share Posted October 2, 2007 It uses standard spokes, you hook the heads into the slots.The advantage comes if you need to change a spoke - they come straight out rather than having to bend/untwine them from the others. You can also change a spoke without having to take the cassette/disc rotor off.Built quite a lot of those hubs a few years back, seemed ok, but spoke breakage was more common than with conventional hubs. Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted October 2, 2007 Author Report Share Posted October 2, 2007 Adam@TartyBikes said: Built quite a lot of those hubs a few years back, seemed ok, but spoke breakage was more common than with conventional hubs.really? why was that? Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted October 2, 2007 Report Share Posted October 2, 2007 cos they don't have flanges longer spokes needed? Quote Link to comment Share on other sites More sharing options...
paolo Posted October 2, 2007 Report Share Posted October 2, 2007 Ehm, I guess it's lighter, but it must be deadly on the spokes... Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted October 2, 2007 Report Share Posted October 2, 2007 samdoman said: really? why was that?The corners where the spokes go into the hub are pretty sharp, even when the hubs and spokes were bedded in together. Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted October 2, 2007 Report Share Posted October 2, 2007 Any one got any pics of a wheel built up on one ?Adam Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted October 2, 2007 Author Report Share Posted October 2, 2007 Adam@TartyBikes said: The corners where the spokes go into the hub are pretty sharp, even when the hubs and spokes were bedded in together.howabout a radial build? Quote Link to comment Share on other sites More sharing options...
Caleb Posted October 2, 2007 Report Share Posted October 2, 2007 if its a cheap front disc hub your after the 24 seven shop on ebay do barnd new sealed ones for £10 Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted October 2, 2007 Report Share Posted October 2, 2007 samdoman said: howabout a radial build?The spokes won't stay in the hub. Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted October 2, 2007 Report Share Posted October 2, 2007 Had one of them a few years back. Worked perfectly Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 2, 2007 Report Share Posted October 2, 2007 Currently becoming pretty 'hot' in the BMX world... Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted October 2, 2007 Author Report Share Posted October 2, 2007 /\yeah, i've seen the sweedish ones and they looked pretty nice, thats one of the reasons i want to try it. Quote Link to comment Share on other sites More sharing options...
strat-trials Posted October 4, 2007 Report Share Posted October 4, 2007 Those BMX ones are mostly so you don't grind through the heads of your spokes. The deore one doesn't look like it would do that, but then again doubt you'll be doing grinds on it. Spose its useful if you bang your hubs a lot...I had one in a back wheel, was fine for riding around on but never used it for trials. I'm sure it'll be fine. Quote Link to comment Share on other sites More sharing options...
Tomm Posted October 4, 2007 Report Share Posted October 4, 2007 Those (BMX) hubs look awesome. Two things though - you have to take your wheel apart completely to change a spoke, and there's no disc mount. Pimp though! Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted October 4, 2007 Author Report Share Posted October 4, 2007 Tomm said: Those (BMX) hubs look awesome. Two things though - you have to take your wheel apart completely to change a spoke, and there's no disc mount. Pimp though!the deore ones have disc mounts and you dont have to rebuild your wheel, they've got keyhole things for the spokes to go through Quote Link to comment Share on other sites More sharing options...
planet x alan Posted October 4, 2007 Report Share Posted October 4, 2007 like the idea of that bmx hub, got the extra bit on it to protect the spokes from smith grinds and stalls and stuff quite cool!and you wouldn't be able to lace a hub in radial pattern if you're gonna use a disk it will just twist it all round wouldnt it? Quote Link to comment Share on other sites More sharing options...
balfa Posted October 4, 2007 Report Share Posted October 4, 2007 Don't buy a shimano hub! I'm sure plenty of people will testify how long the bearings last. If you buy one be prepared to inspect the ball bearings and cones regularly. They are definitely not built for trials. Quote Link to comment Share on other sites More sharing options...
