GyTrials Posted October 1, 2007 Report Share Posted October 1, 2007 (edited) Having a problem trying to crop images!!I cant seem to get the crop tool to go to the size i want it to it seems to be constrained to set sizes if you know what i meanlike there is no deveation from the set pattern of 7*5 10*8 etccan anyone help as its becoming annoying having to use raw in cs3 and crop in cs2Any help would be appreciated cheersSteve Edited October 1, 2007 by GyTrials Quote Link to comment Share on other sites More sharing options...
poopipe Posted October 1, 2007 Report Share Posted October 1, 2007 (edited) christ knowsuse the select tool and crop from the image menu instead?I'd give you the keyboard shortcuts but they've probably changed them like they did with everything else. twats Edited October 1, 2007 by poopipe Quote Link to comment Share on other sites More sharing options...
Rob_P Posted October 1, 2007 Report Share Posted October 1, 2007 Assuming you just mean crop normally?Well number one is the width number 2 is height and 3 is clear.If you wack in whatever number you would like in inches, it may come up with "mm" after but don't worry, it won't matter as long as you dont enter anything into the resolution. Where number 3 is, click clear and that will clear whatevers in the box. I cant see any other way of it causing a problem Quote Link to comment Share on other sites More sharing options...
Mat Tea Why Posted October 1, 2007 Report Share Posted October 1, 2007 I haven't used Photoshop for a long time so this might not be the right name for it or might not work, but to you have snap to points turned on? Quote Link to comment Share on other sites More sharing options...
Has anyone seen my shoe? Posted October 1, 2007 Report Share Posted October 1, 2007 Thats an awesome pic in your screen shot Rob. Quote Link to comment Share on other sites More sharing options...
Rob_P Posted October 1, 2007 Report Share Posted October 1, 2007 No it's not You know why? because I didnt take it, HAR Quote Link to comment Share on other sites More sharing options...
JonMack Posted October 1, 2007 Report Share Posted October 1, 2007 I always do a selection using the fixed ratio tool, and set it to 3:2, then use the crop tool to crop out the selection, thats the easiest way to get it to the right size. Quote Link to comment Share on other sites More sharing options...
Tomm Posted October 1, 2007 Report Share Posted October 1, 2007 On CS2 there's a drop-down box that gives 3 options: Normal, fixed size and fixed aspect ratio. It sounds to me like it's set on fixed aspect ratio. Change it to normal? Quote Link to comment Share on other sites More sharing options...
GyTrials Posted October 1, 2007 Author Report Share Posted October 1, 2007 Assuming you just mean crop normally?Well number one is the width number 2 is height and 3 is clear.If you wack in whatever number you would like in inches, it may come up with "mm" after but don't worry, it won't matter as long as you dont enter anything into the resolution. Where number 3 is, click clear and that will clear whatevers in the box. I cant see any other way of it causing a problem Legend!!Problem now solved cheersTopic can be closed pleaseSteve Quote Link to comment Share on other sites More sharing options...
Has anyone seen my shoe? Posted October 2, 2007 Report Share Posted October 2, 2007 No it's not You know why? because I didnt take it, HARIts still awesome! Quote Link to comment Share on other sites More sharing options...
