Adjustable Headset Spacer
2sixstreet
That would be cool with a stem with no top cap bolt etc because if you fitted that, fitted stem and tightened pinch bolts, then used a tool to spread that apart it would tighten the headset and heighten the risk of having your chest impaled on the stem. And also would be great if the pinch bolts came undone and the stem just fell off before you did a big move.
:P
True though.
That would be cool with a stem with no top cap bolt etc because if you fitted that, fitted stem and tightened pinch bolts, then used a tool to spread that apart it would tighten the headset and give a cleaner look.
That defeats the whole purpose of using it. I'm guessing you wouldnt get the required torque doing it that way. You could hower still use the top cap to tighten your stem down on the spacer, do up the pinch bolts and then remove the top cap. Then again you could do this with any normal stem...
