bousfield19 Posted September 28, 2007 Report Share Posted September 28, 2007 hi i have got a 24seven holroyd with a gearing of 16t front freewheel and 12t fixed rear is this the same gear as a 22tfront fixed 18tfreewheel?it feels a lot harder but i have been told it is the same ratio does any one know how to work it out?thanks jamie Quote Link to comment Share on other sites More sharing options...
jandamna Posted September 28, 2007 Report Share Posted September 28, 2007 (edited) hi i have got a 24seven holroyd with a gearing of 16t front freewheel and 12t fixed rear is this the same gear as a 22tfront fixed 18tfreewheel?it feels a lot harder but i have been told it is the same ratio does any one know how to work it out?thanks jamieHi, I'am not 100% sure but i believe you divide the front tooth number by the back so;16 - 12 = ratio of 1.333*and 22-18 = ratio of 1.222*So 16 - 12 should be slightly harder.Hope ive helped,Jan Edited September 28, 2007 by jandamna Quote Link to comment Share on other sites More sharing options...
