tmks88 Posted September 28, 2007 Report Share Posted September 28, 2007 Im having a problem with my ENO 18T trials freewheel, it moves well until i lock the lockring then it starts moving too hard and when riding on higher speeds it throws the chain off. I tried to clean everything on the freewheel but not help... Im out of ideas maybe someone has had the same problem and found a solution to it... Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted September 28, 2007 Report Share Posted September 28, 2007 must have put something back wrong....or maybe cross-threaded the lockring? does it sit flat?hmmm Quote Link to comment Share on other sites More sharing options...
liam_thornton Posted September 28, 2007 Report Share Posted September 28, 2007 Sorry to sorta hijack your thread, but my Eno is bent, i think. What happens is when I get the chain tension right and the right hand crank is forward it is tight, then when you put the left crank forward it is loose, this is only a problem because I ride left foot forwards. anyone know how to sort this out. Quote Link to comment Share on other sites More sharing options...
tmks88 Posted September 28, 2007 Author Report Share Posted September 28, 2007 must have put something back wrong....or maybe cross-threaded the lockring? does it sit flat?hmmmEverything should be back like it has to be and the lockring is closed properly i tried to open and close it again and again, still the same problem. Its possible to ride but when i move from one spot to another I sometimes like to get high speeds to move faster. Quote Link to comment Share on other sites More sharing options...
