roboet Posted September 28, 2007 Report Share Posted September 28, 2007 Can you give me some comments about YaaBaa 599 model? Is it good for its price? Is it well built? The most important - is it strong? Can one rely on it for everyday use and a little bit of trials riding? Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted September 28, 2007 Report Share Posted September 28, 2007 well...it looks fairly sturdy with a good set of try-all components. The only real bad points that i can see is that it uses a deore rear hub ( freehub wont handle trials for more than a few weeks ) and it runs on vees which although CAN be used for trials, arent the ideal choice, especially no brand aluminum ones.For anyone else that wants to comment on this topic, below is a link of the translated page:http://www.tiny.cc/9twXt Quote Link to comment Share on other sites More sharing options...
MadManMike Posted September 28, 2007 Report Share Posted September 28, 2007 (edited) Most factory ready bikes have poor components, but that seems good - like Dark Biker said you may want to change the rear hub and the brakes but it would be fine if you're just learning - to be honest a Magura HS33 is a good option for the rear brake and that's cheap enough Forgot to add, when I started trials I had the same hub as that, it held up fine for over a year until I started putting more power down so you'd not need to replace it immediately! Edited September 28, 2007 by MadManMike Quote Link to comment Share on other sites More sharing options...
roboet Posted September 28, 2007 Author Report Share Posted September 28, 2007 I won't use the bike for agressive trials, so I guess it will longer. What Hub do you suggest me to buy? As for the brakes - the same answer. They'll do fine for now. If I have problems, I'll change them.Is it strong? I've read (on the "translated" page from YaaBaa.com) that it's fit for street/trials and can move anywhere. That is just what I want, as I won't be doing much trials moves. Just s pedal up from time to time. (Bunny)Hops and rear wheel hops. No big hights, no big pressures on the bicycle. Quote Link to comment Share on other sites More sharing options...
MadManMike Posted September 28, 2007 Report Share Posted September 28, 2007 It looks strong enough to me!Personally I would get a pair of Magura HS33 brakes as the brake upgrade, I'm not too sure on the hub though. Quote Link to comment Share on other sites More sharing options...
roboet Posted September 28, 2007 Author Report Share Posted September 28, 2007 Thank you for your replies. That was what I wanted to hear.Does anyone suggest a Hub replacement?And if/when I replace it, do I have to change other parts? Quote Link to comment Share on other sites More sharing options...
MadManMike Posted September 28, 2007 Report Share Posted September 28, 2007 And if/when I replace it, do I have to change other parts?No, but you'd need someone to build the wheel again as you only replace the hub not the whole wheel - do you have a local bike shop that could rebuild the wheel? Quote Link to comment Share on other sites More sharing options...
roboet Posted September 28, 2007 Author Report Share Posted September 28, 2007 Yes. It's the best in my country. Are you sure you can't suggest a model/brand for the hub? Will an ECHO Hub fit? Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted September 28, 2007 Report Share Posted September 28, 2007 Well, you could replace the hub with something along the lines of a Chirs King(300 ish) or a profile(150ish), or, you could buy a fixed hub ( 70ish), change the cranks (50 ish)and run a front freewheel(30 ish). All three are expensive options, but as MadManMike said, the hub will last for a fair while, if you dont put that much power through the drivetrain, so it might be better to simply replace it when it breaks, and with replacement freehubs at only 15 pounds they aren't such a bad option to consider. Quote Link to comment Share on other sites More sharing options...
roboet Posted September 28, 2007 Author Report Share Posted September 28, 2007 Can you tell me which of these will do a good job (if any): http://www.trialmarkt.de/ (in the left side menu -> Naben) Quote Link to comment Share on other sites More sharing options...
MadManMike Posted September 28, 2007 Report Share Posted September 28, 2007 I don't know much about hubs, but Echo, Chris King, Hope etc will all be a huge improvement on the one it has as standard Quote Link to comment Share on other sites More sharing options...
roboet Posted September 28, 2007 Author Report Share Posted September 28, 2007 OK. I'll probably not brake this one. But in case I do, I just want to know what compatibility issues I might have with a new one? What dimensions (again, if any) should I look for etc. Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted September 28, 2007 Report Share Posted September 28, 2007 What dimensions (again, if any) should I look for etc.135mm spacing, 10mm diameter Quote Link to comment Share on other sites More sharing options...
roboet Posted September 28, 2007 Author Report Share Posted September 28, 2007 Thank you very much. I think I'll buy this bike.But it will be in a week, probably, so I welcome more comments (negative and positive).Thank you all for now. Quote Link to comment Share on other sites More sharing options...
MadManMike Posted September 28, 2007 Report Share Posted September 28, 2007 Good choice, seems a good option!Post pictures up here when you get it Quote Link to comment Share on other sites More sharing options...
roboet Posted September 28, 2007 Author Report Share Posted September 28, 2007 Will do. Thanks again. Quote Link to comment Share on other sites More sharing options...
matt rushton Posted September 28, 2007 Report Share Posted September 28, 2007 I would say Hope Pro2 for hub. Also if you can wait save up and get the 999 as they are the same frame as the old Koxx levelboss.Matt Rushton Quote Link to comment Share on other sites More sharing options...
roboet Posted September 28, 2007 Author Report Share Posted September 28, 2007 matt, I want to have a seatpost and the 999 costs too much for me to ride "a little trials" on it. Thanks for the suggestion. I'll stay with the 599. Quote Link to comment Share on other sites More sharing options...
icemann Posted September 28, 2007 Report Share Posted September 28, 2007 hey iam kinda new.. in this forum.. and new to trials.. i`ve been riding street and some trials for 2 or 3 years.. but now i am thinking for the real trials..anyway.. my choises are YaaBaa Totskoye for now.. or echo pure.. so i was wondering.. did u buy that yaabaa and is it good or the echo is better.. thanks Quote Link to comment Share on other sites More sharing options...
roboet Posted September 28, 2007 Author Report Share Posted September 28, 2007 I'll definately go with the Echo Pure if I were you and wanted to do trials for real. I am buying Yaabaa (and this model specifically), because it is cheap, durable and it is also suited for riding from place to place. If you want to ride trials and be good at it - Echo. Anyway, I've heard that KOXX's (which is the company behind Yaabaa/TryAll/...) prices are a little high for the quality.So, definately not the Yaabaa (not this 599 one, anyway). I'd also recommend Czar if you have the funds. When I buy the bicycle, I'll give some more comments about it here (and some photos probably). Quote Link to comment Share on other sites More sharing options...
icemann Posted September 30, 2007 Report Share Posted September 30, 2007 (edited) well as far as i can see here in bulgaria.. (i am from macedonia but styding here) yaabaa was about 50 euros more expencive than the echo pure.. how is that possible i dont know.. thanks anyway.. this was realy big help for me.. so.. this means that i`ll have to wait to reload the echo`s.. because they are out.. but better that than riding smth that`s no gud for me.. anyway this model of yaabaa>and i dont have the money for tzar.. i was thinking to buy parts one by one.. because i dont have the money.. its the only way.. thanks Edited September 30, 2007 by icemann Quote Link to comment Share on other sites More sharing options...
roboet Posted October 1, 2007 Author Report Share Posted October 1, 2007 Iceman, if you are in Bulgaria, I should explain some stuff to you before you go and get your self robbed. Send me a private message with your ICQ or (better) Skype. We'll talk there. Quote Link to comment Share on other sites More sharing options...
m2rekkk Posted October 1, 2007 Report Share Posted October 1, 2007 well yaabaas seem OK to me and im planning to order the 999 version when my knee is good again (if it gets better ) yaabaas have older version koxx and on the pic that there should be an koxx levelboss old frame as on the yaabaa999 and about the levelboss frame you guys probably know more about it than i do Quote Link to comment Share on other sites More sharing options...
