What Exactly Is Brake Tar?
Jimbo-T-Pro
Ive seen it before, and never thought anything of it, but ive heard it quite alot on here, and am wondering how much difference it makes, because my HS33s are starting to go a bit sloppy, and dont work in the wet ( i know they arent really supposed to,but i live in wales and wet is all we get!!) before i get new pads, should i try tar? thanks
whatever you do do not use tar in the wet!!! in the dry its okish but only in very small amounts. in the wet use koxx greens thats what i use on a medium grind and the wet weather performance is awsome, its very good in the dry aswell a great "english weather" pad i reckon lol
tim
Well, it's just ordinary but sticky tar.
It makes a huge difference but you might find it hard to get used to. It makes the brake really sticky but at the same time much more powerful. I guess you need to learn to apply the correct amount. I use it all the time and couldn't live without it ^_^
Agreed i used it on phat pads and it was a harsh grind and it was the best back brake i have ever seen.
Then again if you have vee brakes on the front then try slapping abit on.
Trial and error i supose.
Echo.Josh
X-x-X
NEVER do that
the vee will stick and not let go, its not good
Untrue, did a whole comp yesterday with a xtr front, smooth rim and a touch of tar, just have to be careful how much you put on.
As many people have said, the best combination for the back maggy is a harsh grind (angle grinded rim) then something like Koxx Browns (I use them) or Rock Pad Blues. This will work well in all weathers. Tar on a smooth rim will work wonders in the dry as far as power is concerned but if its raining loads you'll be screwed. Infact if you want to do anytihng: wet weather + smooth rim = very very bad.
Phil
