kyle-livesey Posted September 24, 2007 Report Share Posted September 24, 2007 What brakes are you running.I actually have two Front. BB7, XT lever Shimano cables on Zoo forks. ( The one pads has a hole in it whoops)Back. Magura 04 lever, Shimano hosing, 4 bolts mounts, plazmatic pads and a light grind on Zoo Pitbull 07. ( Don't think you will ever get a better back brake than this. )I think these are the two best brakes, set up wise at the moment.Whats yours . Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted September 24, 2007 Report Share Posted September 24, 2007 front 185 bb7 avid sd7 lever xtr cable urban forks.rear 05 magura std hose echo cnc mounts control frame(built in cnc booster) 1 koxx red 1 plaz anodized rim.Matx Quote Link to comment Share on other sites More sharing options...
timmorley Posted September 24, 2007 Report Share Posted September 24, 2007 front: bb5 on sd7 lever 160mm rotorback: magura 05 koxx greens on medium grindboth work awsome!!btw this is a mod set up loltim Quote Link to comment Share on other sites More sharing options...
NileBrown™ Posted September 24, 2007 Report Share Posted September 24, 2007 (edited) Front: Avid bb7 185, XTR cable, Avid SD7 Lever - works the nuts and im scared to pull it lol. Rear: Hs33 with Rb lever blade, Koxx Browns - Splendid. Edited September 24, 2007 by nile71091 Quote Link to comment Share on other sites More sharing options...
koxxtrials Posted September 24, 2007 Report Share Posted September 24, 2007 Front: Magura Louise 180mm FR Disc BrakeRear: Magura HS33 Standard Quote Link to comment Share on other sites More sharing options...
Sir_Hops_Alot Posted September 24, 2007 Report Share Posted September 24, 2007 Im running standard hs33 front and back and i think they pretty good. Quote Link to comment Share on other sites More sharing options...
Chris Elson Posted September 24, 2007 Report Share Posted September 24, 2007 2004 mag on the front with koxx browns and water bleed. 2005 mag with koxx yellows and water bleed on the back, harsh grind on both rims, both front and back brakes are verryy good. TPA wheels are very annoying and ive got through 3 in the last couple of months. 74 kings one is on its way though. Chris Elson Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted September 25, 2007 Report Share Posted September 25, 2007 2 x raceline hs33s both with koolstop pads, no grind, and the rear i use with tar Quote Link to comment Share on other sites More sharing options...
Conor the basher. Posted September 25, 2007 Report Share Posted September 25, 2007 Front bb7 203...rear maggie, braided cross over, coust pads in cnc backings, nicesharp grind, on ozonys frame ( super mega stiff)awsom Quote Link to comment Share on other sites More sharing options...
wilf Posted September 25, 2007 Report Share Posted September 25, 2007 (edited) I am running a front magura louise 07 and an 06 hs33 with onza citrus pads Edited September 25, 2007 by wilf Quote Link to comment Share on other sites More sharing options...
JaMmY Posted September 25, 2007 Report Share Posted September 25, 2007 avid bb7 withe echo lite forks and back is 05 maggie water bleed with koxx browns and a medium grind Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted September 25, 2007 Report Share Posted September 25, 2007 on the rear i have a clever/bodged vee conversion from the 25" magura mounts on the old monty 231 x-hydra, i run an XTR vee brake with a 2007 XTR vee lever and pimpin' a-bike linear illegal cable in white/kevlar. i use plaz crvs on a pretty dead grind and they bite and hold perfectly every time on the front i have the same lever and cable setup but a BB7 185mm (well, im supposed to but ukbikestore.com are shite) i used to run a front xtr vee too but im in the process of getting my disc at the moment Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted September 25, 2007 Report Share Posted September 25, 2007 Shimano acera fornt and no baxck brake at the mo LMAO Adam Quote Link to comment Share on other sites More sharing options...
Muel Posted September 25, 2007 Report Share Posted September 25, 2007 Twin Mono Trial 06s, when I get the rear to f**king work. Stripped mounts aren't fun. Quote Link to comment Share on other sites More sharing options...
anzo Posted September 25, 2007 Report Share Posted September 25, 2007 07 Hopes, front and rear. Cant freakin beat em Quote Link to comment Share on other sites More sharing options...
eskimo Posted September 25, 2007 Report Share Posted September 25, 2007 Front: Xtr caliper, CRV's, Odyssey Slick, Avid SD lever Rear: sidehop Blue Oil Bled Magura, Koxx Blue's, Medium grind on Echo 07, Built in booster. Quote Link to comment Share on other sites More sharing options...
Greetings Posted September 25, 2007 Report Share Posted September 25, 2007 Front: 07' BB5 203mm, XTR cable, SD7 leverRear: 04' HS33, Coustsinks, std magura 4-bolt mounts Quote Link to comment Share on other sites More sharing options...
J Trials 31 Posted September 26, 2007 Report Share Posted September 26, 2007 Stock bike: 04' HS 33 on front, HS-22's on the rear.Mod bike: Front and rear Shimano XTR V-brakes.They both work really well considering. Quote Link to comment Share on other sites More sharing options...
El Cristoff Posted September 26, 2007 Report Share Posted September 26, 2007 Front: Avid bb7 185, XTR cable, Avid SD7 Lever - works the nuts and im scared to pull it lol. Rear: Hs33 with Rb lever blade, MY Koxx Browns - Splendid.front: Hope mini 180mmrear: Magura HS-33 '04, coustsink pads, on a light grind, dont think you'll get a better set-up than this to be fair Quote Link to comment Share on other sites More sharing options...
loser Posted September 26, 2007 Report Share Posted September 26, 2007 I use a sd7 lever with sd7 arms on the back, I'm also using plazmatic CRV padsthats on a medium sharp grind.On the front I'm using the same lever/arms but with rock pad greens in the cnc backingsBoth of my brakes are immense, won't slip however hard I try Quote Link to comment Share on other sites More sharing options...
simtradan Posted September 26, 2007 Report Share Posted September 26, 2007 hope mono trial 180 on the frontcnc echo on the back, zoo pads, no grindwould go bb7 and hs33 though if i didn't buy what i have off ebay Quote Link to comment Share on other sites More sharing options...
maty-trials Posted September 27, 2007 Report Share Posted September 27, 2007 front: avid juicy 7 203back : water blead hs33 04 with normal red padsmat Quote Link to comment Share on other sites More sharing options...
JoeEden Posted September 28, 2007 Report Share Posted September 28, 2007 I have a magy 05 on the rear with one plaz pad and one black magy pad it is ok but it slips quite a lot when it wants to, but soon to be a hope mono trial 07 disc brake, and on the front i have a hope mono trial disc brake (the older one im not sure what yr). Quote Link to comment Share on other sites More sharing options...
Krisboats Posted September 29, 2007 Report Share Posted September 29, 2007 Front: 185mm avid bb7, avid SD7 lever. Its "okay".Rear: Magura slaves, RB lever, heatsink backings with rock pad blue material on a decent grind with a super stiff rex frame. Best.... brake.... ever! Quote Link to comment Share on other sites More sharing options...
trialsstar15 Posted September 30, 2007 Report Share Posted September 30, 2007 i run an 05 maggie on the front with maggie red pads and no grind small amount of tar its ok it could be betta lolon the back i run an 5 magie, blue rock pads and a grind lil bit of tar once in a while its amazing best Brake iv eva used Quote Link to comment Share on other sites More sharing options...
