stevenjenkins.klb. Posted September 22, 2007 Report Share Posted September 22, 2007 Rite i was wondering if anyone knows of anyways to get a snapped bolt out of my frame. btw it is snapped rite in you cant take it out with an ajustable. i was thinking about putting a small drill (maybe 3mm) through it and then i may be able to get it out from there. would this work? any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
willy wonka Posted September 22, 2007 Report Share Posted September 22, 2007 where abouts is it stuck? Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted September 22, 2007 Report Share Posted September 22, 2007 drilling the bolt wont work, it will just dig in deeper, ram a screw driver in first and hit the handle with a hammer creating a groove, then use the screwdriver to twist it out.if not, then drill the hole to 6mm, tap the hole, then insert a helicoil to get it back to its original size, and leaving the mounts stronger as a steel insert pwns alu thread Quote Link to comment Share on other sites More sharing options...
2sixstreet Posted September 22, 2007 Report Share Posted September 22, 2007 Drill a hole in it and use an Easy Out. Its a left hand thread tool so when you screw it in, the snapped bolt naturally wants to turn out. Quote Link to comment Share on other sites More sharing options...
David20 Posted September 22, 2007 Report Share Posted September 22, 2007 Take it down to highland, same happened to my old xtp, they sorted it out for me. Quote Link to comment Share on other sites More sharing options...
Ash-Trials Posted September 22, 2007 Report Share Posted September 22, 2007 I got dremel and took about 1mm off of mount on frame arount it so bolt stuck out a bit and got pliers otherwise dremel a cross into it and screw it out.Ash~ Quote Link to comment Share on other sites More sharing options...
