Nick Garland Posted September 22, 2007 Report Share Posted September 22, 2007 Not normally something I would ask about but hey theres always a first.Got a SINGLE phono connection to my DVD player. I need to connect my Xbox 360 and my laptop. My laptop will be running a 3.5mm to phono adaptor. I was thinking if I get 2 of these and then put both of the WHITE connectors into one (ie the white connector from the xbox and the white connector from the pc) then put the two red connectors into the other. Using 2 extension cables connection these to the apropriate connection on the back of the DVD player, thus having 2 sources into 1 input.Only one will be on at a time but its just hassle to keep changing them between. Would this work or is there a simpler way ? Such as a device that allows you to connect multiple inputs and switch between, like the scart switchers. Quote Link to comment Share on other sites More sharing options...
strelly Posted September 22, 2007 Report Share Posted September 22, 2007 This?My flat mate had one similar with xbox360/pc and it worked fine. Quote Link to comment Share on other sites More sharing options...
