shogun_gimp Posted September 19, 2007 Report Share Posted September 19, 2007 Well, i was riding today and noticed that my pedal was wobbley... So i went in and had a look its tight yet its wobbles?Does anyone know why?Do i need a new arm?Help PleaseNigel Quote Link to comment Share on other sites More sharing options...
matt rushton Posted September 19, 2007 Report Share Posted September 19, 2007 If they are square taper then it will have proberly rounded off. And yes you will need a new arm if this has happend.Matt Rushton Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted September 19, 2007 Report Share Posted September 19, 2007 Possibly a new BB aswell depending on what consition the axels in Adam Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted September 20, 2007 Report Share Posted September 20, 2007 u need a new arm mate. If it's a left arm my trick is to use a steel one (the ones covered in plastic) off a supermaket scrapper i found in a backstreet until i can afford new cranks. Cost me f**k all too. Quote Link to comment Share on other sites More sharing options...
Vee Posted September 20, 2007 Report Share Posted September 20, 2007 well id like to point out, he said his pedal wobbles! do you mean your crank arm? if its your crank arm then possibly, but if not its your pedals, bearings are possibly worn and you should get new ones Quote Link to comment Share on other sites More sharing options...
shogun_gimp Posted September 20, 2007 Author Report Share Posted September 20, 2007 CC12345678910 said: u need a new arm mate. If it's a left arm my trick is to use a steel one (the ones covered in plastic) off a supermaket scrapper i found in a backstreet until i can afford new cranks. Cost me f**k all too. Yes it is my left one as thats what i kick with. How Much are they? Quote Link to comment Share on other sites More sharing options...
tom jersey Posted September 20, 2007 Report Share Posted September 20, 2007 Square taper is common to round off etc. Isis the more expensive option but in my opinion a hell of a lot better. Quote Link to comment Share on other sites More sharing options...
willy wonka Posted September 20, 2007 Report Share Posted September 20, 2007 jsymole said: Square taper is common to round off etc. Isis the more expensive option but in my opinion a hell of a lot better.not always more expensive. Quote Link to comment Share on other sites More sharing options...
shogun_gimp Posted September 21, 2007 Author Report Share Posted September 21, 2007 Right i got my dad to have a look at it and hes just taken off the the pedal so.....He said that the thread or the bit where the pedal goes in has worn?That means a new arm i guess? So if thats a yes what should i get? Fairly cheapThanks Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted September 26, 2007 Report Share Posted September 26, 2007 Like i said earlier, find a dumped bike & get the crank puller out... Quote Link to comment Share on other sites More sharing options...
Tomm Posted September 26, 2007 Report Share Posted September 26, 2007 What is actually wobbling? The pedal on the crank, or the crank on the bottom bracket? Try and explain a bit better and you're more likely to get the right answer.If the pedal's wobbling, it will just be the bearings. Unless you've cross-threaded the pedal at some point I doubt it's the pedal threads. Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted September 26, 2007 Report Share Posted September 26, 2007 Iv got an arm if you want it ?Adam Quote Link to comment Share on other sites More sharing options...
nek0 Posted September 26, 2007 Report Share Posted September 26, 2007 Mine's doing the same, tried with different crank bolts but the drive side is shot.The splines themselves are worn, looking at the teeth some of them are worn in an angle so the crank moves towards that empty space But another friend of mine told me to shove a piece of metal for time being.Not sure how critical it is but with the FFW the crank moves 1~2mm sideways... Quote Link to comment Share on other sites More sharing options...
shogun_gimp Posted September 26, 2007 Author Report Share Posted September 26, 2007 well..... just found out the the bearings have gon on the pedal... So i guess i have to get a new pedal right? Wrong? Quote Link to comment Share on other sites More sharing options...
ManxTrialSpaz Posted September 26, 2007 Report Share Posted September 26, 2007 shogun_gimp said: well..... just found out the the bearings have gon on the pedal... So i guess i have to get a new pedal right? Wrong?Yup. Just buy some new pedals and if stuff still wobbles, either you're being fussy or it wasn't your pedals that are broken Quote Link to comment Share on other sites More sharing options...
