danhalson Posted September 19, 2007 Report Share Posted September 19, 2007 hiya ive got a 24 seven holroyd and my brakes keep lossing presure can any 1 tell me y please cheers dan Quote Link to comment Share on other sites More sharing options...
kyle-livesey Posted September 19, 2007 Report Share Posted September 19, 2007 Front hope? If so it probably because it been up side down so the chamber will get air in it. If you pull the lever couple time it should go back to normal. Quote Link to comment Share on other sites More sharing options...
danhalson Posted September 19, 2007 Author Report Share Posted September 19, 2007 Front hope? If so it probably because it been up side down so the chamber will get air in it. If you pull the lever couple time it should go back to normal.the front is an avid and the back is an hs33 but they keep lossin preure so i have 2 keep gettin them rebleed Quote Link to comment Share on other sites More sharing options...
Ste Wilson Posted September 19, 2007 Report Share Posted September 19, 2007 (edited) Are u sure the pistons are sealed properly? Also keep checking the bleed bolts how old are the brakes?H hope i helped ste Edited September 19, 2007 by trials ste Quote Link to comment Share on other sites More sharing options...
danhalson Posted September 19, 2007 Author Report Share Posted September 19, 2007 Are u sure the pistons are sealed properly? Also keep checking the bleed bolts how old are the brakes?H hope i helped ste there only a couple of months old hardly used Quote Link to comment Share on other sites More sharing options...
matt rushton Posted September 19, 2007 Report Share Posted September 19, 2007 What type of Avid is it?And with the Magura you sure its not just your pads wearing down, and if the Avid is a cable not your cable stretching??Matt Rushton Quote Link to comment Share on other sites More sharing options...
danhalson Posted September 19, 2007 Author Report Share Posted September 19, 2007 What type of Avid is it?And with the Magura you sure its not just your pads wearing down, and if the Avid is a cable not your cable stretching??Matt Rushtonnope it isnt strenthing the pads are practicly new so i dunno Quote Link to comment Share on other sites More sharing options...
Ste Wilson Posted September 19, 2007 Report Share Posted September 19, 2007 hm... are they both doing this? Quote Link to comment Share on other sites More sharing options...
danhalson Posted September 19, 2007 Author Report Share Posted September 19, 2007 hm... are they both doing this?yea dunoo y thou Quote Link to comment Share on other sites More sharing options...
Ste Wilson Posted September 20, 2007 Report Share Posted September 20, 2007 are u bleeding them wrong? and once u have bled them are u tightening the bleed bolts up tight enough so they dnt leak?]ste Quote Link to comment Share on other sites More sharing options...
danhalson Posted September 21, 2007 Author Report Share Posted September 21, 2007 are u bleeding them wrong? and once u have bled them are u tightening the bleed bolts up tight enough so they dnt leak?]stei tak the bik 2 a shop and they do it 4 me so i think so ill double check thou thanks Quote Link to comment Share on other sites More sharing options...
trial-biker-ryan Posted September 21, 2007 Report Share Posted September 21, 2007 i tak the bik 2 a shop and they do it 4 me so i think so ill double check thou thanksNo Dig, But try not to use txt tlk, you will get validated quicker if your posts are well presented Now your brakes.. if there only a few weeks old.. get your self on maguras website and register your hs33, then you can hopfully make a successfull warrenty claim, *Note. they NEED to be registered to claim warrenty.. register them then claim a week later or something along those lines.Cheers Ryan Quote Link to comment Share on other sites More sharing options...
basher Posted September 21, 2007 Report Share Posted September 21, 2007 It sounds like one of you pistons is sticking so retracting slowly, and because of that it feels at the lever all wobble like theres nothing there and then gradually comebacks. Get a small allen key and clean all dirt front the sela around your pistons and then pull your maggy lever in and lube up the pistons. Quote Link to comment Share on other sites More sharing options...
danhalson Posted November 11, 2007 Author Report Share Posted November 11, 2007 It sounds like one of you pistons is sticking so retracting slowly, and because of that it feels at the lever all wobble like theres nothing there and then gradually comebacks. Get a small allen key and clean all dirt front the sela around your pistons and then pull your maggy lever in and lube up the pistons.delete topic please Quote Link to comment Share on other sites More sharing options...
