pengsmelly Posted September 16, 2007 Report Share Posted September 16, 2007 (edited) well every now and again my avid keeps locking on. it happens say every half hour, maybe 20 mins, but its really anoying me and at times gettin me into trouble.lol. do you know whats wrong?? is there anyway of stopping it?? cheers matt. Edited September 16, 2007 by pengsmelly Quote Link to comment Share on other sites More sharing options...
willy wonka Posted September 16, 2007 Report Share Posted September 16, 2007 you forget to take your finger off the lever? Quote Link to comment Share on other sites More sharing options...
grantallsop Posted September 16, 2007 Report Share Posted September 16, 2007 Try lubing your cable or the arm on the lever, could just be stuck. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted September 16, 2007 Report Share Posted September 16, 2007 buy a new lever. trust. buy an avid sd7, solves all problems Quote Link to comment Share on other sites More sharing options...
tom jersey Posted September 16, 2007 Report Share Posted September 16, 2007 you forget to take your finger off the lever?LMAO, take it apart hit with a hammer and it will be fine, just give it a clean. Quote Link to comment Share on other sites More sharing options...
pengsmelly Posted September 16, 2007 Author Report Share Posted September 16, 2007 buy a new lever. trust. buy an avid sd7, solves all problemsit is preety much brand new and it is an sd7 lukey got it for alex then i got it off him. Quote Link to comment Share on other sites More sharing options...
manuel Posted September 16, 2007 Report Share Posted September 16, 2007 LMAO, take it apart hit with a hammer and it will be fine, just give it a clean.what ? the finger ? probably cable / lever related .... Quote Link to comment Share on other sites More sharing options...
willy wonka Posted September 16, 2007 Report Share Posted September 16, 2007 what ? the finger ?i was thinking the same.. Quote Link to comment Share on other sites More sharing options...
pengsmelly Posted September 16, 2007 Author Report Share Posted September 16, 2007 LMAO, take it apart hit with a hammer and it will be fine, just give it a clean.well il try looping up the cable see if that works. but not sure if i will be wravking it with a hammer or my finger. lol Quote Link to comment Share on other sites More sharing options...
basher Posted September 16, 2007 Report Share Posted September 16, 2007 Lube the cable and make sure if you have the cable zip tied to the forks ect that is isnt to tight and making the inner cable get stuck. Quote Link to comment Share on other sites More sharing options...
willy wonka Posted September 16, 2007 Report Share Posted September 16, 2007 Lube the cable and make sure if you have the cable zip tied to the forks ect that is isnt to tight and making the inner cable get stuck.and if all else fails hit your finger with a hammer? Quote Link to comment Share on other sites More sharing options...
Cap Posted September 16, 2007 Report Share Posted September 16, 2007 check the pads and spring are in the caliper correctly Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted September 16, 2007 Report Share Posted September 16, 2007 Take the full cable (inner/outer) offSpray loads of lube (GT85 etc) down the outerGrease the inner all the way alongPut the lot back togetherSet up againProblem should disappear Quote Link to comment Share on other sites More sharing options...
JaMmY Posted September 17, 2007 Report Share Posted September 17, 2007 Or just stop put tonnes of water on it at the start of rides lol! :D :D Quote Link to comment Share on other sites More sharing options...
timmorley Posted September 21, 2007 Report Share Posted September 21, 2007 hi, my mate used have this problem alot, most of the time its just because your cable full of grit and dirt. either buy a new cable or take your cable out of your outer cable and give it a good clean and lube both the outer and the inner.if this fails then check you havnt got any sharp turns in the cable mounting to the disc, any sharp turns just increase friction which would explain why the lever gets stuck.tim Quote Link to comment Share on other sites More sharing options...
