JT! Posted September 16, 2007 Report Share Posted September 16, 2007 How?The side with the disc lines up perfectly when tight. But the left side has, well a 4mm gap, which is to be expected.What do i fill that gap with?Cheese?Thanks. Quote Link to comment Share on other sites More sharing options...
King C Posted September 16, 2007 Report Share Posted September 16, 2007 4x1mm thick washers? Quote Link to comment Share on other sites More sharing options...
JT! Posted September 16, 2007 Author Report Share Posted September 16, 2007 4x1mm thick washers?Is it just a case of spacing it out? My main worry is that not much (about a thrid) of the axel is in the dropouts which seems wrong. Quote Link to comment Share on other sites More sharing options...
King C Posted September 16, 2007 Report Share Posted September 16, 2007 Oh yea. Didnt think of that. I not sure then. Quote Link to comment Share on other sites More sharing options...
Greetings Posted September 16, 2007 Report Share Posted September 16, 2007 Use a snail cam on the inside of the drive side of the hub. A snail cam is usually about 3mm thick, I wouldn't worry about the missing 1mm. Quote Link to comment Share on other sites More sharing options...
JT! Posted September 16, 2007 Author Report Share Posted September 16, 2007 Not got any snail cams laying about, if two or 3 1mm spacers will do the trick the chainstay might pull in a bit and i could probably get away with it. I'll give that a try when i find some spacers. Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted September 16, 2007 Report Share Posted September 16, 2007 Use the snailcams ur using to tention your chain on the inside of the frame i think he means, or are you using tugs?Either way spacers will be fine i reckon.Matx Quote Link to comment Share on other sites More sharing options...
King C Posted September 16, 2007 Report Share Posted September 16, 2007 Yea but assuming hes not riding a monty and hes got ,say a deng frame, then he'll already be using the cams on the inside Quote Link to comment Share on other sites More sharing options...
JT! Posted September 16, 2007 Author Report Share Posted September 16, 2007 I'm riding a Ciqúerererreerrere or what ever they're called, they have their own built in tugs. Quote Link to comment Share on other sites More sharing options...
JT! Posted September 16, 2007 Author Report Share Posted September 16, 2007 All done now thanks for the help.I think there's just enough axel in the dropouts to get by, anyone know how to pronounce the name of the frame? Quote Link to comment Share on other sites More sharing options...
Token Posted September 16, 2007 Report Share Posted September 16, 2007 Think it's Pronounced: 'Se-kwen-ah' Quote Link to comment Share on other sites More sharing options...
JT! Posted September 16, 2007 Author Report Share Posted September 16, 2007 Think it's Pronounced: 'Se-kwen-ah'Ooo i like that.Sounds even better in a mexican accent. Quote Link to comment Share on other sites More sharing options...
Muel Posted September 17, 2007 Report Share Posted September 17, 2007 I doing the same. I'm using a disc mount to fill the gap. Quote Link to comment Share on other sites More sharing options...
JT! Posted September 17, 2007 Author Report Share Posted September 17, 2007 I doing the same. I'm using a disc mount to fill the gap.A disc mount? Quote Link to comment Share on other sites More sharing options...
Greetings Posted September 17, 2007 Report Share Posted September 17, 2007 Think it's Pronounced: 'Se-kwen-ah'Not Chi-kwen-ah ? Quote Link to comment Share on other sites More sharing options...
