billyboi Posted September 14, 2007 Report Share Posted September 14, 2007 Hello im thinking of buying some magura brakes but it says they are water bled... is this any good an will i have to change more often will they slip ect...or are they the same as normal bled? thank you Quote Link to comment Share on other sites More sharing options...
Muel Posted September 14, 2007 Report Share Posted September 14, 2007 Yes.To find out more, use the search. Quote Link to comment Share on other sites More sharing options...
billyboi Posted September 14, 2007 Author Report Share Posted September 14, 2007 Ok thank you Quote Link to comment Share on other sites More sharing options...
Vee Posted September 14, 2007 Report Share Posted September 14, 2007 If your goin to do it, do it in the bath and comletely under the water!Vee Quote Link to comment Share on other sites More sharing options...
BenLeacockâ„¢ Posted September 14, 2007 Report Share Posted September 14, 2007 If your goin to do it, do it in the bath and comletely under the water!Veeand make sure that the lever is higher than the pistons! Quote Link to comment Share on other sites More sharing options...
David20 Posted September 14, 2007 Report Share Posted September 14, 2007 If your goin to do it, do it in the bath and comletely under the water!VeeFrom past experiences, basin bleeds have always been shite, bleed kit works a lot better for me anyway. But yeh, water bleeds are ace. Quote Link to comment Share on other sites More sharing options...
pengsmelly Posted September 14, 2007 Report Share Posted September 14, 2007 i run water bleed now. well good. Quote Link to comment Share on other sites More sharing options...
jandamna Posted September 14, 2007 Report Share Posted September 14, 2007 Does anyone run a water bleed in the "new style" maggies? I'am not sure whether i should bleed mine with water when it needs to be bled or not Jan Quote Link to comment Share on other sites More sharing options...
*Tom* Posted September 15, 2007 Report Share Posted September 15, 2007 Does anyone run a water bleed in the "new style" maggies? I'am not sure whether i should bleed mine with water when it needs to be bled or not JanI've got a water bleed in my new back magura and its fine . . . works better than i did with oil in it Tom Quote Link to comment Share on other sites More sharing options...
jandamna Posted September 15, 2007 Report Share Posted September 15, 2007 I've got a water bleed in my new back magura and its fine . . . works better than i did with oil in it TomAlright, thanks Jan Quote Link to comment Share on other sites More sharing options...
LauraPalmer Posted September 15, 2007 Report Share Posted September 15, 2007 water bleed works good - just one thing - the brake will not last as long as if the pistons oil themselves! they will quit work after about a year... Quote Link to comment Share on other sites More sharing options...
Pixie Posted September 15, 2007 Report Share Posted September 15, 2007 I think they do work, cause a lot of people use them.but there is one down-fall, they duff up the seals but that happens if you do it all the time.And next time use the search! Quote Link to comment Share on other sites More sharing options...
billyboi Posted September 15, 2007 Author Report Share Posted September 15, 2007 Wow im sorry i didnt think of using the search... and i have been told to use it in the first post and did.....but thank you anyway Quote Link to comment Share on other sites More sharing options...
Pixie Posted September 15, 2007 Report Share Posted September 15, 2007 Wow im sorry i didnt think of using the search... and i have been told to use it in the first post and did.....but thank you anywayIts stated in the rules to use the search before you make a topic. Quote Link to comment Share on other sites More sharing options...
billyboi Posted September 15, 2007 Author Report Share Posted September 15, 2007 as i said i forgot... and have been told already and used them its a mistake im sure almost everyone has made... but thank you anyway Quote Link to comment Share on other sites More sharing options...
Simpson Posted September 15, 2007 Report Share Posted September 15, 2007 water bleed works good - just one thing - the brake will not last as long as if the pistons oil themselves! they will quit work after about a year...but there is one down-fall, they duff up the seals but that happens if you do it all the time.They... are both folk lore... / shit.... people are still running maggies with water bleeds over 3 years old... it really doesnt damage the brake at all... its just that the viscosity of the water is a lot better for trials as it gives, sharper quick on/off braking feel great for trials... shit for something like downhill where you dont want the brake to be on or off... you may just want to slow down... kinda thing.... so yea do it... the only downside is you get oil everywhere and that it voids the magura warrantee..... (of course unless you re bleed the brake with oil before your send it back ) Quote Link to comment Share on other sites More sharing options...
jandamna Posted September 15, 2007 Report Share Posted September 15, 2007 Its stated in the rules to use the search before you make a topic.I know i'am a new member and all, but just give the guy a break, the first person who posted a reply already told him to use the search, having a go at someone and "stating the rules" wont get you validated...Jan Quote Link to comment Share on other sites More sharing options...
tom jersey Posted September 15, 2007 Report Share Posted September 15, 2007 Yes.To find out more, use the search.Exactly there was a topic on this like two days ago! Quote Link to comment Share on other sites More sharing options...
willy wonka Posted September 15, 2007 Report Share Posted September 15, 2007 Exactly there was a topic on this like two days ago!who cares!gives us a reason to give abuse to new members. Quote Link to comment Share on other sites More sharing options...
JoeEden Posted September 16, 2007 Report Share Posted September 16, 2007 You should have faster pad movement and not so much of a slugish pull than magura'a bled with fluid. Quote Link to comment Share on other sites More sharing options...
mandry1991 Posted September 16, 2007 Report Share Posted September 16, 2007 yeah thay run well nice i have a water bleed and very nice. Quote Link to comment Share on other sites More sharing options...
