Dave Anscombe Posted September 14, 2007 Report Share Posted September 14, 2007 (edited) Hi in need of some super quick advice on how to sort out a really bent to fcuk disc rotor it rubs in just about every spot badly.....i would get a new rotor but im skinto and got a ride going on sunday....thank you dave x Edited September 14, 2007 by mrkoxx Quote Link to comment Share on other sites More sharing options...
El Cristoff Posted September 14, 2007 Report Share Posted September 14, 2007 lay it flat and twat the bent side with a hammer?or is your caliper in line properly? Quote Link to comment Share on other sites More sharing options...
sex_on_wheels Posted September 14, 2007 Report Share Posted September 14, 2007 adjustable spanner and bend it back. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted September 14, 2007 Report Share Posted September 14, 2007 adjustable spanner and bend it back.werd Quote Link to comment Share on other sites More sharing options...
James Quigley Posted September 14, 2007 Report Share Posted September 14, 2007 what size is it, I have a 203 rotor (little bent) laying around or I could posibly get hold of a 185 Quote Link to comment Share on other sites More sharing options...
Muel Posted September 14, 2007 Report Share Posted September 14, 2007 adjustable spanner and bend it back.Do that, use the caliper as a jig and bend it slightly, spin, bend, spin, bend , spin and so on, until the rotor is true. Quote Link to comment Share on other sites More sharing options...
Krisboats Posted September 14, 2007 Report Share Posted September 14, 2007 Do that, use the caliper as a jig and bend it slightly, spin, bend, spin, bend , spin and so on, until the rotor is true.Yep, i might just add that before you put the adjustable on your rotor give it a quick clean first to remove any oil/crap. Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted September 14, 2007 Author Report Share Posted September 14, 2007 THANK YOUUUZ.Dave xtwattage with a hammer sounds fun Quote Link to comment Share on other sites More sharing options...
El Cristoff Posted September 14, 2007 Report Share Posted September 14, 2007 twattage with a hammer sounds funyeah dave, tis well fun! really stupid, but fun Quote Link to comment Share on other sites More sharing options...
NileBrownâ„¢ Posted September 15, 2007 Report Share Posted September 15, 2007 What I normally do is ride about with the front brake on, (like if you were bedding the pads in) and the rotor should heat up quite a lot and then use the spanner method. Just makes life easier thats all Quote Link to comment Share on other sites More sharing options...
tom jersey Posted September 15, 2007 Report Share Posted September 15, 2007 Put it between two pallets and jump on it! Quote Link to comment Share on other sites More sharing options...
pengsmelly Posted September 15, 2007 Report Share Posted September 15, 2007 Put it between two pallets and jump on it!thats what i do just with two bits of wood, it worked. Quote Link to comment Share on other sites More sharing options...
_Owen. Posted September 15, 2007 Report Share Posted September 15, 2007 (edited) Ride along quite fast, and hold your brake on a little bit, it will warm up and if you hold the brake in the right place it will warp itself straight. I used to keep having to do it with mine, really p*sses me off! Let me guess, its a mono trial brake/rotor?Oh yeah, and i know its not as fun as smashing the crap out of it with a hammer, but if its a mono trial, the rotors are so weak you can just bend it back with your hands! Edited September 15, 2007 by owentrialsman Quote Link to comment Share on other sites More sharing options...
timmorley Posted September 15, 2007 Report Share Posted September 15, 2007 alright guys n girls, sumtimes when this happens its just because your rotor bolts arnt equally tightened up. so before you go and twat your disc take it off then tighten the bolts up opposite sides and with equal pressure, (reccomend a torque wrench ). this helps because sometimes it may tweak the rotor on the hub.cheerstim Quote Link to comment Share on other sites More sharing options...
