Rob Thomson Posted September 13, 2007 Report Share Posted September 13, 2007 Hello all,Well just wondering what would be the best 4 bolt booster to use for my Adamant A1, currently running it without and Mr. Flex is out to play and I don't like it much..So yeah just want something that fits well...My 4 bolt knowledge is fully up with the best of them and apparently some might not fit very well/at all due to frame spacing?CheersRob Quote Link to comment Share on other sites More sharing options...
Muel Posted September 13, 2007 Report Share Posted September 13, 2007 Anything will fit. Quote Link to comment Share on other sites More sharing options...
Greetings Posted September 13, 2007 Report Share Posted September 13, 2007 Unless the new adamants are different, the frame definitely shouldn't flex. My brake on the 06 A1 is rock solid. Put an HS booster on a while ago just as an experiment and couldn't feel the difference. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted September 13, 2007 Report Share Posted September 13, 2007 I wouldn't say you need one from experience, but certain people like their brakes to be REALLY stiff, if so...Measure your frame spacing, should be ~100mm on that one, then just check what spacing the boosters are. For example, an Echo 4-Bolt is 87-100mm spacing (centre-to-centre of bolt holes). Quote Link to comment Share on other sites More sharing options...
willy wonka Posted September 13, 2007 Report Share Posted September 13, 2007 (edited) what you need is my gu booster buy it off me Edited September 13, 2007 by willy wonka Quote Link to comment Share on other sites More sharing options...
Simpson Posted September 13, 2007 Report Share Posted September 13, 2007 (edited) The most trouble with mods is more tyre clearance, so a lot of mod boys run RB's cos they come up and then across rather than across, get one cheap off here bout 10quidish! check spacing though im pretty sure they generically fit most framesedit: Oh wank A1 not A3 ignore me Edited September 13, 2007 by Simpson Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted September 13, 2007 Report Share Posted September 13, 2007 buy my onza carbon booster would fit a treat, its super light and stiff and includes long bolts and spacers! you know you want to! Quote Link to comment Share on other sites More sharing options...
