Really Strange, Gay Problem :(
El Cristoff
Hi everyone, i recently built up a Echo '07 rim onto a viz! mod hub. I have trued it and stuff, but if i lean to one side on my bike, the pads rub on the rim. This problem is driving me crazyyyy!
Also, it seems like then snail cams are not holding... I dont know why though.
Finally, i think one of my magura 33 calipers is being homo, and is being lazy, or the cnc backings are rubbing on the 33. I have no idea, anyone be able to help with that one?
Cheers everyone in advance,
Chris
Edited by elcristoff-t-pro
If the wheel is centre, then give each and every spoke a 1/4 or 1/2 half turn, should stop the spokes from letting the rim move to the non-drive side. Becuase when you pedal, the chains force on the cog pushes the wheel to the non-drive side.
If you can understand that :P
Edited by chocolate_bikes
this is what i was going to say after he answered about his spoke tension...
in simple terms: tighten all your spokes an equal ammount.
it's easiest to start at the valve and work round putting on one tweak each time (1/4 turnish)
you might have to go round the wheel a couple of times (Y)
i do understand that :)
thats a awnser and a half, cheers mate :)
