What Would Happen If.....
NVWOCI WVS
ok, so im thinking of saving weight/getting my brake set up better, so im thinking of replacing my current revell rear rim with a revell front rim and shrinking my rear tyre down to a 2.35 high roller.
would this be any good? i know the front is only single wall, but if im super smooth on it woud it work?
my reasoning is: it's lighter and it's narrower so i'll be able to get a better setup on my vee hopefully
ive considered this. i dont think the rim would hold up too much though
Pretty sure Rowan Johns uses a front Echo 07 rim on the back.
i use it because it is slightly narrower than the slugger rear rims, its a shade lighter than a DX32 and as strong / stronger too. it also seems to have thicker sidewalls (although i could be wrong there) which kind of adds up. the rear rim is far too overkill for me. oh i also use a single wall tyre on the back which also works fine ....
EDIT : just reread the opener - go down to a 2.35 whatever....
Edited by manuel
