Ste Wilson Posted September 10, 2007 Report Share Posted September 10, 2007 hi i am just wondering if there are anyways of improving a front disc brake (hope mini) without costing a fortune e.g. tar and rim grind on a hs33 or good pads etc.... is there any equivalent for a front brake?thnx alot ste! Quote Link to comment Share on other sites More sharing options...
Ticker Posted September 10, 2007 Report Share Posted September 10, 2007 (edited) Yes theres a few things you can do.You could take your pads out and sand them down a bit, and give them a clean.Also give your rotor a good clean.You might also want to give your brake a re-bleed.Doing that should make your brake better. Edited September 10, 2007 by Ticker Quote Link to comment Share on other sites More sharing options...
harrylumley Posted September 10, 2007 Report Share Posted September 10, 2007 I think what he means is are there any alternatives, eg. hope mono trial, avid bb7, magura hs33 or a vee.It depends on what you like, say if you had to ride down a big hill to the train station or something, it would be no good with a magura or a vee because it would just eat the pads and change the compound.There are a wide range of magura pads which are designed for all different rim surfaces, grind, tar or smooth, it depends on what pads you run.Harry! Quote Link to comment Share on other sites More sharing options...
ManxTrialSpaz Posted September 10, 2007 Report Share Posted September 10, 2007 I'm not too sure about how easily they can be acquired, but Plazmatic do pads + disc for disc brakes - not too sure whether the disc pattern is IS though. Quote Link to comment Share on other sites More sharing options...
willy wonka Posted September 10, 2007 Report Share Posted September 10, 2007 I think what he means is are there any alternatives, eg. hope mono trial, avid bb7, magura hs33 or a vee.It depends on what you like, say if you had to ride down a big hill to the train station or something, it would be no good with a magura or a vee because it would just eat the pads and change the compound.There are a wide range of magura pads which are designed for all different rim surfaces, grind, tar or smooth, it depends on what pads you run.Harry!vees are good for front brake, use plazzies on smooth rim and it wont wear down that quick. Quote Link to comment Share on other sites More sharing options...
Ste Wilson Posted September 10, 2007 Author Report Share Posted September 10, 2007 thanks Quote Link to comment Share on other sites More sharing options...
timmorley Posted September 11, 2007 Report Share Posted September 11, 2007 alright mate, if you have got a hope mono mini then i would definatly reccomend getting some kool-stop pads they make your brake sooooooooo much better its unreal! another thing would be would get a slighty bigger rotor for example if you have got a 160 rotor get a 180 dont go too big thow otherwise you mite smash it wen you do side hops etc.hope i've helpedtim Quote Link to comment Share on other sites More sharing options...
