giantwhore Posted September 5, 2007 Report Share Posted September 5, 2007 (edited) Debating on whether to buy a 74kingz tensioner. Only thing is, im using QR's and ive hear that you cna run into problems.I don't wanna be tightening it every 2 seconds and i sidehop to the right.....Anyone got any useful feedback?Chris Edited September 5, 2007 by giantwhore Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted September 5, 2007 Report Share Posted September 5, 2007 Tap your axle and run bolts, will make it a bit stronger as it is as you then have the weight being transferred through solid metal as opposed to a hollow tube, and will allow you to get the Kingz working better too Quote Link to comment Share on other sites More sharing options...
Krisboats Posted September 5, 2007 Report Share Posted September 5, 2007 Debating on whether to buy a 74kingz tensioner. Only thing is, im using QR's and ive hear that you cna run into problems.I don't wanna be tightening it every 2 seconds and i sidehop to the right.....Anyone got any useful feedback?ChrisGet an angle grinder or file and make deep grooves in the metal around the axle hole.My tensioner allowed the wheel to move in the dropout (i'm a bit heavy and kick hard), cutting the grooves in gave anough grip between the tensioner and the frame to stop it moving everywhere. Quote Link to comment Share on other sites More sharing options...
26inch Posted September 5, 2007 Report Share Posted September 5, 2007 My mates kept slipping so we drilled a hole in the tensioner and stuck a long bolt through that rested on the underneath of the dropout so it couldnt move up, works a treat now Quote Link to comment Share on other sites More sharing options...
