Flexy Rear Stock Wheel
Tim-Hill..Yeah Mate
extremly anoying problem that doesnt want to go...
07 echo rim
pro 2 hub
sapim spokes
hub is all good, no wobbles
spokes are very tight, maybe too tight? i have tightend them after the build to try and stop flex... no luck.
one thind which could be the problem, when the hub bolts are at the top of the dropout the wheel is slightly over to the left.
build was done by lbs, has built about 5/6 riders wheels in trowbridge (all mod untill now) have no problems with untill now.
any suggestions?
Tim.
what do you mean by flexy ? as in you get rub on the brakes ?
you are always going to get some flex on a 26 wheel - some from spokes and some from frame flex....
if its causing brake rub with the wheel bang in the middle of the pads then there is a problem...
just make sure the rim is bang in the centre of the brake setup ... oh and you crank up the proII bolts right up.
EDIT : and like the guy VVVVV make sure it is dished correctly - always a winner
Edited by manuel
it sometimes flexes when i kick hard e.g gapping. if the backwheel is whipepd out a tiny tiny bit it rubs the pads.
yeah i dont think its dished correctly, but now the spokes are effin tight and hardly do up now, il take it back to the builder see what he thinks.
cheers.
Tim.
Same problem here, fecking annoying... can't figure it out :S didn't happen before I changed my hub, and now its flexing :S feck it, anyone got any advice?
Jonny, your rim is fooked anyway. :lol:
Tighten the nipples up until they won't tighten any more, or run shorter spokes.
In other words, get a mod!
Yours just has a huge buckle in it. you then set the pads up as close as you could to the rim.
I said i'd unbuckle it but kind of forgot in the excitement of spraying your frame :$
iv had this problem a couple of times.
Take a nice 6mm allen to the Pro2 bolts and give them a tighten, (OR whip em out and grease them, then put them back in and tighten them)
it usually happens if your sidehopping and you land on the dropout or catch it, takes a knock and loosens the bolt ever so slightly.
Wayne.
