sam ere luvin :Ptrials:P Posted September 2, 2007 Report Share Posted September 2, 2007 Hi there, I have a big problem with snake bites. what is the ideal pressure to prevent this?Thanks sam Quote Link to comment Share on other sites More sharing options...
monty boi Posted September 2, 2007 Report Share Posted September 2, 2007 Im not sure, i never go by psi, i just feel it, i like mine medium to hard,Adam ere luving trials:P Quote Link to comment Share on other sites More sharing options...
Muel Posted September 2, 2007 Report Share Posted September 2, 2007 Use the search newbie, tis a wonderful thing. Quote Link to comment Share on other sites More sharing options...
mods Posted September 2, 2007 Report Share Posted September 2, 2007 i run a pretty hard pressure in my rear mod tyre. more chance of buckling your wheel though. Quote Link to comment Share on other sites More sharing options...
ilikeriding Posted September 2, 2007 Report Share Posted September 2, 2007 (edited) you wont get em if its rock hard, id advise getting smoother instead, or a dh innertube/double walled tyre Edited September 2, 2007 by afroman Quote Link to comment Share on other sites More sharing options...
bonzojim Posted September 2, 2007 Report Share Posted September 2, 2007 hi mate ,i use try-all tyres and have 22 rear 23 front this pressure suits my riding , i use slightly more for street, hope this helps a bit.james s. Quote Link to comment Share on other sites More sharing options...
_Owen. Posted September 2, 2007 Report Share Posted September 2, 2007 Use the search newbie, tis a wonderful thing.Haha agreed, thousands of topics on tyre pressures. Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted September 2, 2007 Report Share Posted September 2, 2007 Next time you ride, go out with a much harder pressure than usual.Find a gap or something you would normally be rimming on, and go at it again and again, letting a tiny bit of pressure out each time you do it, until you are JUST rimming on impact.That's the kind of pressure you sound to be looking forAlternatively, take a pump out with you and work the other way, stopping just after you stop rimming out Quote Link to comment Share on other sites More sharing options...
basher Posted September 2, 2007 Report Share Posted September 2, 2007 Well obviously the harder it is the less chance of snake bites. Danny swindlehurst think its spelt like that uses moped inner tubes i think and he was selling them a while back so may be ask him about them. Quote Link to comment Share on other sites More sharing options...
harrylumley Posted September 2, 2007 Report Share Posted September 2, 2007 Sam, u are harsh as hell! and run like 14psi, try step it up to 18 or 20, cheif rims out just hoping on your bike!are we riding hebden tomorrow? Ring me if your are.Harry! Quote Link to comment Share on other sites More sharing options...
Echo-Scott Posted September 2, 2007 Report Share Posted September 2, 2007 If you get a double strength tube or a large diameter one there will be alot less snake bites and you can run lower pressure. I'm running a large diameter tube at about 7-8 psi and i have only had one snake bite since I got it which was about a month or so ago. Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted September 2, 2007 Report Share Posted September 2, 2007 I my self run around about 20 to 25 psi in my rear mod tyre and i would say normaly 10 to 15 in the front... its really just trial and error to be honnest Quote Link to comment Share on other sites More sharing options...
sam ere luvin :Ptrials:P Posted September 5, 2007 Author Report Share Posted September 5, 2007 Thanks all, I have been running 19 psi my rear tube and that seems to be a better result but i am still getting the odd snake bite , but i have ordered a kenda heavy duty tube so that shud do the trick. Quote Link to comment Share on other sites More sharing options...
dozydame Posted September 5, 2007 Report Share Posted September 5, 2007 the best thing to do is to pump your tyres up pretty hard to get to the place your ridin because your get there quicker. then let your tyres down to bout 10-15 PSI each.(well thats what i do, depends how heavy you are, and what tyres you've got) it helps with bounce, and will naturally make you become a smoother rider so you don't rim out and get pinches. Quote Link to comment Share on other sites More sharing options...
Adam Hurd Posted September 5, 2007 Report Share Posted September 5, 2007 hi sam i will set your psi if you want???talk when i cya mate bye now Quote Link to comment Share on other sites More sharing options...
poopipe Posted September 5, 2007 Report Share Posted September 5, 2007 pressure doesn't make a sod of difference unless you run about 40 psi. If it's an old tyre and it pinches all the time you need a new one. Otherwise give the inside of the tyre a good coating of talcum powder before you put the tube in and stop smacking it into sharp corners Quote Link to comment Share on other sites More sharing options...
Alex@Flawless Bikes Posted September 5, 2007 Report Share Posted September 5, 2007 I run mine at about 18psi - 20psi and im about 10 stone, don't like my tire to soft. My mate runs his at about 10psi and he is a good 2stone heavyier then me, he just rims out alot! Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted September 5, 2007 Report Share Posted September 5, 2007 Andy b by any chance?lol Quote Link to comment Share on other sites More sharing options...
Alex@Flawless Bikes Posted September 5, 2007 Report Share Posted September 5, 2007 (edited) Andy b by any chance?lolThats the one! <<<<<<<<< Your a member at long last I have been trying to get out and ride ALL week but not luck, you out riding tomorrow by any chance! Edited September 5, 2007 by E6v6i6l Quote Link to comment Share on other sites More sharing options...
sam ere luvin :Ptrials:P Posted September 5, 2007 Author Report Share Posted September 5, 2007 Hi there, I just got a kenda tube and it is a BEAST!!! I realy think this will prevent snake bites. Quote Link to comment Share on other sites More sharing options...
dec Posted September 8, 2007 Report Share Posted September 8, 2007 If you get a double strength tube or a large diameter one there will be alot less snake bites and you can run lower pressure. I'm running a large diameter tube at about 7-8 psi and i have only had one snake bite since I got it which was about a month or so ago.hiya m8 i run mine at about 10-14 psi in rear and i am gettign alot of snake bites i am running a 2.125 with inner tube is there any bigger ones i can get cheers dec Quote Link to comment Share on other sites More sharing options...
Krisboats Posted September 8, 2007 Report Share Posted September 8, 2007 ideal pressure = bike weight + rider weight / riding style * smoothnessNah, there isn't an ideal pressure, just factor the things in above and go with whatever is best for you personally. Quote Link to comment Share on other sites More sharing options...
Echo-Scott Posted September 8, 2007 Report Share Posted September 8, 2007 hiya m8 i run mine at about 10-14 psi in rear and i am gettign alot of snake bites i am running a 2.125 with inner tube is there any bigger ones i can get cheers decYeh. You could get a kenda tube from tarty. My mate recently bought one and it litterally just fits in the tyre. Its also quite thick as well. Quote Link to comment Share on other sites More sharing options...
