Vee Posted September 2, 2007 Report Share Posted September 2, 2007 HI, Just need abit of help with gearing, I use to ride 22t up front and 16t on rearIv just changed to a 18t on the rear and its made loads of difference to ride, makes the bike feel so much lighter and responsiveTh only thing is I will be getting some new cranks and i think the biggest chainring I can get on them is 16twhat would i need on the back to get the same ratio as I have now?Any help is much appreciatedThanksVee Quote Link to comment Share on other sites More sharing options...
Phreemann Posted September 2, 2007 Report Share Posted September 2, 2007 HI, Just need abit of help with gearing, I use to ride 22t up front and 16t on rearIv just changed to a 18t on the rear and its made loads of difference to ride, makes the bike feel so much lighter and responsiveTh only thing is I will be getting some new cranks and i think the biggest chainring I can get on them is 16twhat would i need on the back to get the same ratio as I have now?Any help is much appreciatedThanksVeeI make it a 13T rear you'll need with a 16T front.22 / 18 = 1.2222So to get that ratio with a 16T front, 16 / 1.2222 = 13.09114716T front, 13T rear. Quote Link to comment Share on other sites More sharing options...
Vee Posted September 2, 2007 Author Report Share Posted September 2, 2007 Could I just ask how you got that?Divide 22 by 18 to get a ratiothen 16 by the ratio to get the sprocket size?Thanks alotVee Quote Link to comment Share on other sites More sharing options...
Phreemann Posted September 2, 2007 Report Share Posted September 2, 2007 Could I just ask how you got that?Divide 22 by 18 to get a ratiothen 16 by the ratio to get the sprocket size?Thanks alotVeeYeah, that's it.You can work it backwards to check it's right. 22 divided by 18 = 1.22222216 divided by 13 = 1.2307692Which is close enough for this, and as close as you can get. Quote Link to comment Share on other sites More sharing options...
Vee Posted September 2, 2007 Author Report Share Posted September 2, 2007 Thanks alot, ill be writing this down haha Vee Quote Link to comment Share on other sites More sharing options...
Phreemann Posted September 2, 2007 Report Share Posted September 2, 2007 (edited) Thanks alot, ill be writing this down haha Vee For reference,Gear Ratio = Number of teeth on driving sprocket ÷ Number of teeth on driven sprocketTherefore, when re-arranged;Number of teeth on driven sprocket = Number of teeth on driving sprocket ÷ Gear RatioAnd;Number of teeth on driving sprocket = Number of teeth on driven sprocket x Gear Ratio Edited September 2, 2007 by Phreemann Quote Link to comment Share on other sites More sharing options...
