Steve Tiller Posted September 2, 2007 Report Share Posted September 2, 2007 This stem has been on my bike ever since i start trials about 2 years ago. From what i can remember it did it then to. So is this something to worry about? Steve Quote Link to comment Share on other sites More sharing options...
Captain Scarlet Posted September 2, 2007 Report Share Posted September 2, 2007 Is this from your stem, or is it the noise that you thought was your headset? Quote Link to comment Share on other sites More sharing options...
Krisboats Posted September 2, 2007 Report Share Posted September 2, 2007 UNdo the stem clamp, wipe them bars and stem with a clean cloth to remove any grit or muck that may be causing the creak, then put grease in the bolt threads and whack everything back together REALLY tight. Should sort it out for you Quote Link to comment Share on other sites More sharing options...
JoeEden Posted September 2, 2007 Report Share Posted September 2, 2007 Hi there just undo the top cap undo the two bolts on the side of the stem and push the stem down then tighten it back up and try tighting the handle bars up if that doesnt work i would take it easy and get a new stem or maybe handle bars, well i hope that helped mate. Quote Link to comment Share on other sites More sharing options...
