Echo Pure 06
kid creole
Looks really nice man! I like it!
If Im not mistaken, that pic looks like it was taken in St Osyth (Y) I might be going down there on friday 7th to ride (as long as the weather's nice..) :)
how do you like that DMR tensioner?
I don't know about Alain, but I run the same tensioner, and they're pretty sweet.. I need to tension mine another notch though, but yea they're great & it works perfectly for me..
the dmr tensioner ain't to bad but you have to adjust it every few weeks cause it loses tension. its probably worth spending £20 more to get a rohloff
I have the rohloff but it doesn't fit cause my chainline is too little. It needs like at least 54mm. And it doesn't take 1/8" chains too well, let alone a 1/8" chaine with kmc quicklink which sticks out another 1 or so mm. It must tension well though. I took it apart to grease all the bolts since i'm so anal about my bike components and i had a lot of trouble bolting it back together under the tension of the spring.
