TOBY-E Posted August 31, 2007 Report Share Posted August 31, 2007 Orite people Right Ive had my hope now for just under a year now its been perfect , it hasn't been bled i haven't touched it since i got it.Then today i went out for a ride and it sort of seized up the wheel wont hardly move.Ive tried pushing the pistons out and it worked for about 10 mins then seized up again. i thought i had a lazy piston but i didn't think that could happen with hopes.So any advice would be gratefully appreciated.Thanks in advance Toby(i did try the search but nothing came up that was to any use) Quote Link to comment Share on other sites More sharing options...
Ticker Posted August 31, 2007 Report Share Posted August 31, 2007 You could have a lazy piston or your pistons may not be retracting properly. This happened to my hope, what i did was.. Take your wheel out of the fork.. Take your pads out.. Pump your brake a bit so you can see the calipers.( be carefull not to pump it too much as your calliper could pop out, which will leak all your fluid out and you will need a full re bleed.) . Get a rag and spay a bit of wd-40 on it. Then wipe all inside your brake and on the callipers to get rid of any muck that could be stopping them from retracting.. Then put the brake pads back in and That worked for me.This is what i think is wrong with it, it sounds to me like your brake could do with a good service as from what i can gather it hasn't been well maintained.If it isn't a lazy piston then i can't think what it is.Maybe someone else on the forum knows.Hope this helps. Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted August 31, 2007 Report Share Posted August 31, 2007 The caliper goin to fall off the forks is it? if u pump too hard ticker haha, might want too tighten them bolts, unless u mean the pistons.Good guide though ^.Matx Quote Link to comment Share on other sites More sharing options...
Ticker Posted August 31, 2007 Report Share Posted August 31, 2007 Mat Smith said: The caliper goin to fall off the forks is it? if u pump too hard ticker haha, might want too tighten them bolts, unless u mean the pistons.Good guide though ^.MatxShut up Mat, yes i got confused i meant pistons not calliper. Quote Link to comment Share on other sites More sharing options...
ThYp Posted September 1, 2007 Report Share Posted September 1, 2007 Thats what I did too when I had that problem with my Hopes. I really had to do a LOT of pumping on my lever to get my pads/pistons readjusted again... Worked really fine for me! Nice guide Ticker !Grtzz, ThYp Quote Link to comment Share on other sites More sharing options...
basher Posted September 1, 2007 Report Share Posted September 1, 2007 Take pads out and give the pistons a good greaseing and oiling as they will just be stick. And may be a rebleed aswell but that may be not nesisary Quote Link to comment Share on other sites More sharing options...
JoeEden Posted September 2, 2007 Report Share Posted September 2, 2007 I had that problem with my hope mono trial front brake i just took the brake pads out sprayed the pistons with some wd 40 and made sure the wheel was straight and the wheel didnt move to the side at all and now its sorted its excellent, i hope it help mate. Quote Link to comment Share on other sites More sharing options...
harrylumley Posted September 2, 2007 Report Share Posted September 2, 2007 I had this problem with mine so i sold it to Ticker who then had to sort it out and i bought an 07 Harry! Quote Link to comment Share on other sites More sharing options...
maxwellduryea Posted September 4, 2007 Report Share Posted September 4, 2007 If i were you i wouldnt use wd-40, i would try a different lube. Ever heard of tri-flow? works wonders on all moving parts. Teflon loaded! It's great stuff! Quote Link to comment Share on other sites More sharing options...
